Upgrade from 2023.1.6 to 2024.1.6
Version 2023.1.6 → 2024.1.6
Im planning this upgrade and firstly I’m assuming I need to do this in steps
2023.1.6 → 2023.1.30
2023.1.30 → 2023.2.20
2023.2.20 → 2024.1.6
If anyone can confirm if this is correct, or if I am able to jump 2023.1.6 → 2024.1.6 in one jump
Also all i can find on epic web is a patch manual / minor upgrade user guide or a major guide that covers 10.X to kinetic 2023.x i cant see anything that covers a version increment.
I am currently not a live site and have minimal data within the test company
You do it in one jump, but during the process database scripts will run and you will basically see a different script run for each of the major release steps along the way.
I did an upgrade from 22.x to 24.1 recently using the 2024.1 upgrade release guide. They are all basically the same, but with 24 you need to follow the server requirements closely and make sure the .net 8 pieces are installed.
