Upgrade from 305 to 400 need help!
Hi
run the files from the command line
Regards,
Jose Ferrer
To: vantage@yahoogroups.comFrom: ccarden@...: Fri, 25 Jul 2008 10:57:15 -0500Subject: RE: [Vantage] Upgrade from 305 to 400 need help!
Charlie,I am out of ideas. Do you know is there are any domain policies in affect that would prohibit the installation? We looked at local policies but not domain. That is the last idea that I have.From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Charlie WilsonSent: Friday, July 25, 2008 9:04 AMTo: vantage@yahoogroups.comSubject: RE: [Vantage] Upgrade from 305 to 400 need help!Done still not work even after a restart.~Charlie_____From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf OfCharles CardenSent: Friday, July 25, 2008 9:11 AMTo: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>Subject: RE: [Vantage] Upgrade from 305 to 400 need help!Open Internet Explorer.Select Tools/Internet OptionsClick the Security TabSelect Local Intranet and click the Sites buttonUncheck the Automatically detect intranet networkCheck all 3 boxes listedClick the advanced tabAdd your local domain to the list of websites, e.g. thisdomain.comFrom: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] OnBehalf Of Charlie WilsonSent: Friday, July 25, 2008 7:58 AMTo: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .comSubject: RE: [Vantage] Upgrade from 305 to 400 need help!Yes please guide me on how to do this.~Charlie_____From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com>.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups<mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>]On Behalf OfCharles CardenSent: Friday, July 25, 2008 8:18 AMTo: vantage@yahoogroups <mailto:vantage%40yahoogroups.com>.com<mailto:vantage%40yahoogroups.com>Subject: RE: [Vantage] Upgrade from 305 to 400 need help!I think you have already tried copying the data locally and ensuring theprogram is unblocked. Right?Is your local (intranet) domain the same as your internet domain? If so thenthe system may not be able to detect your local domain correctly and isrestricting program installation. If that is the case you may have to openinternet explorer and manually add your domain as an intranet domain. If youare unsure how to do this let me know.From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] OnBehalf Of Charlie WilsonSent: Friday, July 25, 2008 6:43 AMTo: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .comSubject: RE: [Vantage] Upgrade from 305 to 400 need help!IE Enhanced Security Uninstalled - CheckCommand Prompt - CheckExecute MFGSYS803.exe - Houston we have a problem. "Access Denied"Any other suggestions?~Charlie_____From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com>.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups<mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>]On Behalf OfCharles CardenSent: Friday, July 25, 2008 7:29 AMTo: vantage@yahoogroups <mailto:vantage%40yahoogroups.com>.com<mailto:vantage%40yahoogroups.com>Subject: RE: [Vantage] Upgrade from 305 to 400 need help!Two more things to try.1. Open and command prompt window and run the Setup.exe program. Don't runthe .exe that brings up the install menu just the one that installs themfgsys. I don't have the DVD handy so I can't tell you exactly which one itis. This will tell you if windows explorer has any software executionrestrictions.2. Uninstall the Internet Explorer Enhanced Security ConfigurationTry number 1 first. If that works you are set to go. If you ever use theserver to access the internet (not advisable) then you most definitely wantto do number 2 above or it will be a real pain to browse for anything.From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] OnBehalf Of Charlie WilsonSent: Friday, July 25, 2008 5:59 AMTo: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .comSubject: RE: [Vantage] Upgrade from 305 to 400 need help!NO software restriction policies defined. Still not working. Anything else Ishould look for?_____From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com>.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups<mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>]On Behalf OfCharles CardenSent: Thursday, July 24, 2008 4:14 PMTo: vantage@yahoogroups <mailto:vantage%40yahoogroups.com>.com<mailto:vantage%40yahoogroups.com>Subject: RE: [Vantage] Upgrade from 305 to 400 need help!I ran into this with one of my machines a few months ago. I am trying togive you the right answer but I can't remember for sure. It had something todo with a local security policy getting set inadvertently. If I rememberright execute the local security policy under control panel. If you haveanything under software restriction policies, just right click SoftwareRestriction Policies and select Delete Software Restriction Policies. Ibelieve if you have anything in there it will keep the Vantage setup fromrunning because it is being recognized as a 16 bit program.From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] OnBehalf Of Charlie WilsonSent: Thursday, July 24, 2008 9:20 AMTo: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .comSubject: [Vantage] Upgrade from 305 to 400 need help!I'm working on upgrading a test server from 8.03.305 to 8.03.40X i'm amfallowing the instructions as stated in the manual. But when i go to run thefile that is the actual server upgrade i get an error that states. "Windowscan not access the specified, device, path, or file. You may not haveappropriate permissions to access the item." well seeing as that i am adomain admin i dont believe this is actually a permissions issue. I'mrunning this file off the DVD they send you in the mail to do the upgrade.Any help any one.[Non-text portions of this message have been removed]________________________________DISCLAIMER:This e-mail, including attachments, may include confidential and/orproprietary information, and may be used only by the person or entity towhich it is addressed. If the reader of this e-mail is not the intendedrecipient or his or her authorized agent, the reader is hereby notified thatany dissemination, distribution or copying of this e-mail is prohibited. Ifyou have received this e-mail in error, please notify the sender by replyingto this message and delete this e-mail immediately.[Non-text portions of this message have been removed]No virus found in this incoming message.Checked by AVG - http://www.avg. <http://www.avg. <http://www.avg.<http://www.avg.com> com> com>comVersion: 8.0.138 / Virus Database: 270.5.5/1570 - Release Date: 7/24/20086:59 AM[Non-text portions of this message have been removed]________________________________DISCLAIMER:This e-mail, including attachments, may include confidential and/orproprietary information, and may be used only by the person or entity towhich it is addressed. If the reader of this e-mail is not the intendedrecipient or his or her authorized agent, the reader is hereby notified thatany dissemination, distribution or copying of this e-mail is prohibited. Ifyou have received this e-mail in error, please notify the sender by replyingto this message and delete this e-mail immediately.[Non-text portions of this message have been removed]No virus found in this incoming message.Checked by AVG - http://www.avg. <http://www.avg. <http://www.avg.com> com>comVersion: 8.0.138 / Virus Database: 270.5.5/1570 - Release Date: 7/24/20086:59 AM[Non-text portions of this message have been removed]________________________________DISCLAIMER:This e-mail, including attachments, may include confidential and/orproprietary information, and may be used only by the person or entity towhich it is addressed. If the reader of this e-mail is not the intendedrecipient or his or her authorized agent, the reader is hereby notified thatany dissemination, distribution or copying of this e-mail is prohibited. Ifyou have received this e-mail in error, please notify the sender by replyingto this message and delete this e-mail immediately.[Non-text portions of this message have been removed]No virus found in this incoming message.Checked by AVG - http://www.avg. <http://www.avg.com> comVersion: 8.0.138 / Virus Database: 270.5.5/1570 - Release Date: 7/24/20086:59 AM[Non-text portions of this message have been removed]________________________________DISCLAIMER:This e-mail, including attachments, may include confidential and/orproprietary information, and may be used only by the person or entity towhich it is addressed. If the reader of this e-mail is not the intendedrecipient or his or her authorized agent, the reader is hereby notified thatany dissemination, distribution or copying of this e-mail is prohibited. Ifyou have received this e-mail in error, please notify the sender by replyingto this message and delete this e-mail immediately.[Non-text portions of this message have been removed]No virus found in this incoming message.Checked by AVG - http://www.avg.comVersion: 8.0.138 / Virus Database: 270.5.5/1570 - Release Date: 7/24/20086:59 AM[Non-text portions of this message have been removed]________________________________DISCLAIMER:This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.[Non-text portions of this message have been removed]
_________________________________________________________________
Connect to the next generation of MSN MessengerÂ
http://imagine-msn.com/messenger/launch80/default.aspx?locale=en-us&source=wlmailtagline
