Vantage will not support USB, however I use Mettler Toledo scales and
all of them have both USB AND Serial connections. You need to make
certain that you set the port settings on the host PC to match the
Vantage port settings exactly. Go to your PC Device Manager/Ports and
look at the Properties of COM1. I have mine set as follows:
Bits Per Second: 9600
Data Bits: 7
Parity: Even
Stop Bits: 2
Flow Control: None
Make sure you set Vantage port settings up exactly the same way and your
scale should work.
Keep in mind that you only get the weight from the scale OR manually
enter the weight, you do not have the option to do both. My shipping
people were complaining that Vantage didn't grab the scale weight. I
spent hours getting my scale working and once I did I had to immediately
turn it off because the shipping people hated not being able to key in
the weight manually.
Todd
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Bob Sanders
Sent: Wednesday, February 20, 2008 11:00 AM
To:
Subject: [Vantage] USB scales on Vantage?
We learned that Vantage is only configured to read scales that are
connected via Serial Port. All of our scales are USB. Is there a way
to modify Vantage so that it will accept a USB connected scale at our
Insite Manifest station. We have Mettler Toledo scales, and we tested
yesterday thru a COM port, but Vantage did not recognize the connection
so no data was transferred.
Bob Sanders
Manager Information Technology
KERUSSO
P.O. Box 32
Berryville, AR 72616
Phone: 800-424-0943 Ext. 263
Fax: 870-423-3568
Web Site: www.kerusso.com
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
