Use instr/position/locate in BAQ
Hi all,
is it possible to use any of these functions in BAQ?
They should give the same result in SQL. Is there a similar function in BAQ that does this, i.e. returns the position of the first occurrence of a string in another string?
Thanks for your help.
Regards
Hymal7
Those are commands for MySQL.
Look for SQL Server ones.
CHARINDEX
I did test this and it worked.
