I did have an issue with my joins. I appreciate the assistance.
--- In vantage@yahoogroups.com, Waffqle Driggers <waffqle@...> wrote:
> Are the fields on a separate table? If so, you may want to check your
> joins.
> Otherwise, it may be a bug or a quirk in the report. When you look at the
> actual xml file, is the data in it?
> On Thu, Dec 2, 2010 at 10:01 AM, Mike <mikeyto_96@...> wrote:
> > Right, I modified the RDD to include the fields that I need and brought
> > them into the crystal report.
> > --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Waffqle
> > Driggers <waffqle@> wrote:
> > > You may need to make a custom Report Data Definition. Reports don't
> > always
> > > carry every field from a given table.
> > > On Thu, Dec 2, 2010 at 9:29 AM, Mike <mikeyto_96@> wrote:
> > > > Has anyone had difficulties before with getting data to populate in
> > UDF's
> > > > for Crystal based reports used in Vantage, ie Travler, Sales Order Ack?
> > I
> > > > can see data in some of the fields but not all when I know there is
> > data for
> > > > those fields in the related modules themselves.
