Using a calculated field in a Quick Search 10.0.700.4
Older post, but I figured out you need to type in the calculated field. There is an SCR still not out for this bug.
Hi,
I'm trying to make a Quick Search to look through the QuoteHed and QuoteDtl to let the user enter a piece of text and match it to a calculated field that includes the quote header comment plus quote detail part number, description, and comment.
The query works fine, but the Quick Search entry will not show me the calculated field as a criteria column. I can let the user search each individually, but it would work smoother if the calculated field would show up.
Anyone tackled this?
Joe
Joe D. Trent
Bigham Ag Equipment
