Using a Dataview in a switch case
You can bind the selected view option to a TransView column like this but it’s not exposed in studio so you must alter your app json and then SaveApp via REST
Dashboard Doesn't Load Results if parameter is empty - BAQ works - #21 by jbooker
If you force set epBindingViewOption like this, then you can trigger onColumnChanged of TransView.ViewOption
