Thanks!
This is what the completed code looks like:
Dim edv As EpiDataView = CType(oTrans.EpiDataViews("QuoteHed"), EpiDataView)
edv.dataView(edv.Row)("QuoteComment") = vbCrLf & vbCrLf & "Thank you for the opportunity to quote on the below and for the inquiry." & vbCrLf & vbCrLf & "Looking forward to receiving your purchase order." & vbCrLf & vbCrLf & "Have a great day!" & vbCrLf & vbCrLf & "Thanks,"
> Above should work to declare your table...While in the script editor you can then go to Tools, test code to see if you get the message
> ** Custom Code Compiled Successfully. **
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of ppipaulz
> Sent: Monday, February 07, 2011 4:14 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Using customization - button to add text to a text box
> hey guys I'm trying to create a button (succeeded at this :)) in the Vantag 8.4 Quote Entry screen that will (when pressed) add some canned text to the Quote Entry - Header - Comments - text field.
> I went into customization, added the button, when through the event wizard and setup a new click event. Then for the code section
> I tried this:
> QuoteHed.QuoteComment.Text = "Test test test"
> and
> txtQuoteComment.Text = "Test test test"
> I get thsi error message: Error: BC30451 - line 65 (319) - Name 'QuoteHed' is not declared.
> Any ideas how I can access the Text property of a text field to then alter it?
> thank you
