I have the tPartsToFind Query working, but having an issue with the odata pull.
let
PartsToFind = Table.RemoveColumns(
Table.TransformColumns(
Table.AddColumn(
Table.Group(
Table.AddColumn(
if(Table.IsEmpty(dt("tPartsToFind"))) then
#table(type table [PartNumber = text], {{"Part1"},{"Part2"},{"Part3...etc"}}) // You could use this versus a named table
else
dt("tPartsToFind") // Use my named table called tPartsToFind
, "GrpBy", each "EZ") // Add pseudo aggregator column GrpBy to each row
, {"GrpBy"}, {{"PnTable", each _, type table [PartNum=text,GrpBy=text]}}) // Group into table
, "PartsToFind", each Table.Column([PnTable], "PartNumber")), // Use all of our PartNums in our pseudo group table into list
{"PartsToFind", each Text.Combine(List.Transform(_,Text.From),"&PartsToFind="), type text}) // Aggregate each list item with a new copy of the ¶m= dates will need more here
,{"GrpBy", "PnTable"})
in
PartsToFind
let // OData Feed Pull
// Encode Basic Authentication manually (username:password in Base64) : Change appropriately
Base64Auth = "Basic " & Binary.ToText(Text.ToBinary("datapuller:mypass"), BinaryEncoding.Base64),
// API Key : Change appropriately
ApiKey = "mykey",
Headers = [
#"Authorization" = Base64Auth,
#"X-API-Key" = ApiKey,
#"Content-Type" = "text/plain"
// Query Parameter(s)
partsToFind = Table.FirstValue(PartsToFind),
baseTableData = OData.Feed("https://myserver/api/v2/odata/VTAERO/BaqSvc/JobDetails/"&"?PartsToFind=" &partsToFind, Headers, [Implementation="2.0"])
in
baseTableData
In this one I keep getting an error: Expression.Error: The import PartsToFind matches no exports. Did you miss a module reference?
