Using RDD in BarTender
How can I use an RDD in a new BarTender label?
Create a new report style using the RDD. Then create a SSRS to generate the bartender label. I am not certain how Bartender uses the report, but that is where I would start.
I just ran a test in 2024.1.8 and I was able to get an RDD report to export as a Bartender Text file to our Azure share.
When i open the file it looks normal with the first two lines containing the Bartender script commands then labels then field data.
Wahoo - it works now.
Note: I also tried a BAQ Report and I was NOT able to get that to work.
DaveO
