I am trying to set the NonConf.CommentText to the UD11.Character02 field based on which UD11 code was selected via dropdown in the NC Entry screen. My dropdown works and I saved the UD 11 code number in the NonConf.RepairCode_c field. My UD column maintenance shows the NonConf table is synced and the field was available in the screen customization as a mapping choice. Why can’t I pick it in my BPM code? When I ctrl+shift to get suggestions I can see the other NonConf fields, but not RepairCode_c.
System.Drawing.Bitmap CS1061 ‘NonConfRow’ does not contain a definition for ‘RepairCode_c’ and no extension method ‘RepairCode_c’ accepting a first argument of type ‘NonConfRow’ could be found (are you missing a using directive or an assembly reference?)
//get UD11 table
Ice.Tables.UD11 UD11;
//get temp table for updated NonConf record
var NewRecord = ttNonConf.FirstOrDefault();
//get key1 code from new record
var code = NewRecord.RepairCode_c;
//link UD11 and NonConf on UD11.Key1
UD11 = (from UD11_row in Db.UD11
where UD11_row.Company == Session.CompanyID
&& UD11_row.Key1 == code
select UD11_row).FirstOrDefault();
//set NonConf.CommentText to UD11.Character02
NewRecord.CommentText = UD11.Character02;
