> You are right again. They want to see it. Also our part data (boms)The other option, if you're looking at the import process, is to have this
> are imported from another package thru service connect. The transfer
> was setup by an epicor consultant. The current import does not utilize
> the alternate method so the primary BOM gets populated.
> Perhaps its time to figure out how service connect actually works;-)
information populate the Purchasing Notes for the part instead of or in
addition to adding it to the engineering files.
When you move to 8.03, you'll have access to BPM which can do some of this
kind of work as well.
Best,
Mark W.
