Hi, Jennifer.....No, our system is a fresh install, no upgradef from a
previous version. Might I inquire as to what you discovered ?
Gary
Gary
--- In vantage@yahoogroups.com, "Jennifer" <jmesiano@...> wrote:
> Gary,
> Did you upgrade from a prior version or is this a fresh install? We
> may have identified the problem. I need someone else to test the
> theory.
> Jennifer Mesiano
> Walton Signage
> IT Manager
> 210-886-0644 x 315 (work)
> 210-818-2676 (mobile)
> --- In vantage@yahoogroups.com, "Gary Franks" <garyfr2003@> wrote:
> > We're definitely having similar stability issues with the
> > appservers...just not on SQL2005 or 64-bit hardware.....
> > Gary
> > --- In vantage@yahoogroups.com, "Jennifer" <jmesiano@> wrote:
> > > Is anyone experiencing appserver issues? I cannot keep my live
> > > database stable for more than a day or two at a time. The
> > > appservers lock up or crash. We have had months of tuning from
> > > Epicor which only seems to have exacerbated the problem. Please
> > > email me offline jmesiano@
> > > 1 dedicated server (no other applications installed)
> > > v8.03.305i
> > > SQL 2005 - 64 bit
> > > MS Windows 2003 Server SP2 Standard
> > > Jennifer
> > > --- In vantage@yahoogroups.com, "Brad Feazell" <Brad_feazell@>
> > > wrote:
> > > > We are running the following in 64-bit Windows Server 2003
> > > > environments on 64-bit SQL Server 2005 with no problems.
> > > > - 8.00.810c (production)
> > > > - 8.03.305h (test)
> > > > - 8.03.403a (test)
> > > > There are no issues with the mixture of 32-bit and 64-bit. We
> > > found
> > > > the best performance to be in a single server configuration
> > > although
> > > > we haven't tested the two server setup in a long while.
> > > > Brad Feazell
> > > > IT Manager | Dril-Quip, Inc.
> > > > --- In vantage@yahoogroups.com, Chad Corkrum <chadcorkrum@>
> wrote:
> > > > > With SQL on a seperate server I don't see any reason why you
> > > > couldn't run it on a 64bit version.
> > > > > On the same machine though your going to run into issues
> as
> > > > OpenEdge and Vantage would be running in a 32bit emulated
> world
> > > and
> > > > you could run into issues.
> > > > > But on a seperate machine you don't have the memory
> > > constraints
> > > > associated with the 32bit version of Windows/SQL.
> > > > > Not sure of milage on a seperate server we are running SQL
> > > 2005
> > > > (32bit) on the same server and Vantage and supporting about 90
> > > users.
> > > > > You'll have network latency to deal with as the Vantage
> server
> > > is
> > > > going to get the input transfer it to OpenEdge then across the
> > > > network to SQL and vise versa when pulling info from the DB.
> > > > > Jennifer <jmesiano@> wrote:
> > > > > Does anyone have the above setup? Please email me
> > > > offline. I'm
> > > > > curious as to how you have things setup for optimal
> performance.
> > > > > Take the Internet to Go: Yahoo!Go puts the Internet in your
> > > pocket:
> > > > mail, news, photos & more.
> > > > > [Non-text portions of this message have been removed]
