Thanks Ken and Brian - just the nudge I needed !!
I searched the 'tools user guide' but did not see it covered in there
bw
bw
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> You will need to have at least two tables in your query (which you do, but just saying).
> Start with Part, and add RcvDtl.
> In the Phrase Builder where you define the relations, change the "WhichItem" column in the relation header from "each" (the default), to "last".
> Then on the panel where you define the sorting options outside of the relation builder, sort the query on part and then receiptdate in ascending order.
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
> Â Â Â Â bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bw2868bond
> Sent: Tuesday, December 01, 2009 10:33 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] V8.03.4xx BAQ question
> BAQs are not my forte and I could use a nudge in the right direction.
> I want to use the part and rcvdtl tables to return the LAST receiptdate for parts within a part number range
> I can set up the BAQ with the tables and set the criteria on the parts.
> How do I tell the BAQ to only give me the latest receiptdate?
