I agree the duplicate is the easiest method.
If your rules are similar you can salvage them. For instance, if in
the first part there is a size selection and in the second part the
size will also be selected, but will call different parts you can do
this by changing the method. The rule will follow the material
sequence number.
Be careful if you are going to delete parts from the second parts
method. Make sure that you delete the rule from it in the
configurator before deleting the part in the method. If not the
rule will still be hanging out there. I learned this the hard way.
Basically:
1. Delete any rules before you delete any parts.
2. Change components on your method and the rule will follow the
material number.
Jeremy Slate
Senior Product Engineer
Helmer, Inc.
15425 Herriman Boulevard Noblesville, IN 46060
jslate@...
sequence number.
Basically:
material number.
Jeremy Slate
Helmer, Inc.
jslate@...
--- In vantage@yahoogroups.com, Ed Ortiz <zx6rr@...> wrote:
> Hi Todd,
> The easiest way to copy the Product Configurator from one part to
another is by using the "Duplicate" function in Part Maintenance.
> When the new part already exists and has a BOM I use this process
to copy a configuration from one part to another:
> 1. I copy the BOM from the new part to a Microsoft Excel
spreadsheet.
> 2. I then erase the BOM in the new part.
> 3. Once erased I use the "Get Details" function and copy the BOM
and the Product Configurator from the existing part into the new
part.
> 4. I then use the "Clear All" function to delete the BOM.
> 5. Once the BOM has been deleted, I copy and paste the BOM from
the Microsoft Excel spreadsheet I created earlier.
> The product configurator will be there, but the rules will be
wrong. Re-do the rules and everything should work.
> I hope this helps!
> Ed Ortiz
> Sr. Project Engineer
> Manitex, Inc.
> 3000 S. Austin Ave.
> Georgetown, TX 78627-1609
> www.manitex.com
> Todd Hofert <todd@...> wrote: Is
there a way to copy a configuration from one part to another? I have
> spent a considerable amount of time developing a configuration
for a
> part. I have to create another configuration for a different part
about
> 90% of which is identical to my existing configuration. Ideally,
I would
> like to copy / import / export the completed configuration to
this new
> part then modify that rather than start all over. Does anyone
know if
> this is possible and if so how?
> Thanks
> Todd Hofert
> This e-mail and any attachments may contain confidential and
privileged
> information. If you are not the intended recipient, please notify
the
> sender immediately by return e-mail, delete this e-mail and
destroy any
> copies. Any dissemination or use of this information by a person
other
> than the intended recipient is unauthorized and may be illegal.
