Update:
The session are not hanging. They will close on their own after about 60
minutes. Epicor's workaround was to allow more server sessions in the
database config so that don't run out and get the error. Problem is each
session takes 64Mb of RAM while it is open.
would be hard to tell which session was which. They will close on their own
if you don't run out of resources first.
E:\epicor\oe100b\bin\_mprshut.exe -0 e:\epicor\mfgsys80\db\mfgsys
Hope that helps!
Brian
> Could you tell me how to kill the ODBC connections in Promon?You can kill them under the shutdown database options, but I would think it
> How to get to Promon and the steps required?Sure. Create a shortcut on your server desktop as follows:
Hope that helps!
Brian
