Joe, if you are using a wedge cable with the scanner, the scanner
should act just like keyboard input. We are implenting 8.03 April 1st,
and if I recall the default in Vantage is to use the Tab key. You will
have to program the scanner to send a Tab after the barcode it read in.
I am familiar with PSC scanners, and these come with a programming
book - you scan barcodes in the book to configure the scanner...
HTH,
Jeremy Jackson
HTH,
Jeremy Jackson
--- In vantage@yahoogroups.com, "Joe Rojas" <jrojas@...> wrote:
> Hello,
> If you are using an HHP IT3800 bar code scanner, did you have to do
any
> programming to the scanner before using it with Vantage 8.03?
> If so, could you share your programming with me?
> Thanks,
> Joe Rojas
> IT Manager
> TNCO, Inc.
> 781-447-6661 x7506
> jrojas@...
