Bruce,
These are parameters in the .mfgsys file (in the config folder).
Open the file in Notepad and you will see the entries
_____
Sent: Friday, August 11, 2006 4:21 PM
Subject: RE: [Vantage] V8 MES Clock In question
Brian,
We are getting ready to move to 8.0, and this the answer to one of my
issues I will have to track down. We are using a customized mfgsys
file. Its command line looks like:
"P:\TS2APPS\-EPICOR\mfgsys80\-Client\Client\-MfgSys.exe -MES
/CONFIG=pilot80.-mfgsys"
Could I simply do this:
/CONFIG=pilot80.-mfgsys /UserID value=[data] /Password value=[data]-"
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
From: HYPERLINK "mailto:vantage%40yahoogroups.com"vantage@...
[mailto:HYPERLINK
"mailto:vantage%40yahoogroups.com"vantage@...] On Behalf
Of Brian Boyes
Sent: Friday, August 11, 2006 10:40 AM
To: HYPERLINK "mailto:vantage%40yahoogroups.com"vantage@...
> I've set up the MES terminal as an automatic log-in
> with a generic user and password just to simply start
> the MES program. When an employee goes to clock in,
> they are presented with a Vantage log-in and password
> prompt. Is there a way to get around this?
You need to set up a Vantage account for running MES. For example, set
the account name and password to data. Then, if you aren't already using
a customized mfgsys file for MES, make a copy of the default.mfgsys
file. Make the following changes to these lines:
<UserID value="data" />
<Password value="data" />
Make sure you change your Vantage shortcut to use the new config file.
It sounds like we are doing the same sort of thing as you. We have a
clock-in terminal with a barcode gun. Employees simply scan the barcode
on their badge (and hit OK on a touch screen) to clock-in to the system.
Brian
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.10.9/416 - Release Date: 10/08/2006
