I assume, even though you don't run MRP, actually DO single order (or gloabally) schedule your jobs.
If you don't, you will have to as - job material requirements get their requirement date from the OP start date they are tied to.
The dispatch works whether you run MRP (or the Global) or not. It just needs scheduled jobs to dispatch.
I have not checked 404 (recent install) to see the how the 404 dispatch handles display of Unreleased jobs.
Released job OPs should always appear. Unreleased ideally appear but are either in a seperate section or inter mixed with Released jobs and have a display method in place for identifying them as unreleased.
Other tools (scheduling boards) require Load to be generated. (Load is a seperate table that essentially mirrors the actual OpDtl schedules). This is triggered during MRP if you specify scheduling of unfirmed jobs and is also triggered by the global scheduler. You can also regenerate it directly via a flaky (in 404) app "Generate Shop Load".
Rob Brown
randyduly <randy.duly@...> wrote:
Hello everyone-
I need a little more additional information concerning the Priority
Dispatch Report. I was talking with another user who have made the
jump from Vantage 6.1 to Vantage 8.00 and he said that he had no
problem with the Priority Dispatch report. But after talking with him
a little longer he said that he uses MRP, which automatically
schedules the job and that is why his report works.
We don't use MRP, so any jobs that were open in Vantage 6.1 when we
converted over does not show up in Vantage 8.03.4xx Priority Dispatch
Report.
Anybody got any ideas on this?
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
It takes about 13 man-hours to recreate 800 jobs in this manner. If
you split the work up between 3-6 people, it is managable. If you
have any windows desktop macro programs you are comfortable with, you
can automate much of the otherwise manual entry (cutting down the
time req'd considerably). I've read that other people have been
successful using the SendKeys (vbScript) function out of Access to
act as a macro tool. (This doesn't work well out of excel. I suspect
excel itself - being one big object/event driven engine - tries to
grab Focus too often and the key strokes get sent to the wrong app
window.)
Rob Brown
Hello everyone-
Report.
wrote:
>fullying import existing Jobs with full details.
> We imported from a non-Vantage legacy system and gave up trying to
>engineered) and generate details, engineer and schedule in Vantage.
> We just import the Job header data (unreleased and not
window.)
>Vantage 6.1 to
> Rob Brown
> We are still in the testing phase. We made the jump from
> 8.03.404a and our Priority Dispatch Report will only show any newjobs
> that we put in Vantage 8.03. It seems nothing from 6.1 carriedover.
> Anybody else had this problem?between 0000-00-00 and 9999-99-99
> Thanks in advance.
