V8 - simple VB help
bwalker,
With your help I have been making some progress. The
"oTrans_adapter_AfterAdapterMethod" method did work for disabling and
enabling my objects (Button, Combo) as needed on the
"Quote\Line\Detail" sheet - Update and GetNewQuoteDtl events.
I have also added another Button and Combo to another sheet -
"Quote\Line\Mfg Details\Quote Details\Materials\Detail" but have yet
been able to handle the events like I did for the Quote\Line\Detail
sheet. The same "afteradapter" method does not seem to work.
Is there a way to determine what adapter is be used at any particular
point?
I guess I don't understand how the "oTrans_adapter_AfterAdapterMethod"
relates to the whole Quote module.
Am I explaining the situation correctly... do you have a suggestion?
Bill
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> > Can I ask what event you would use to "disable" the button after the
> > line is saved OR deleted before saving?
> > Thanks again...
> afteradapter method - use the example the wizard gives for the case
> statement and add "Update" and "Delete" and possibly "DeleteById"
> cases and then button.enabled = false in each of those....
Any VB experts to answer a simple question or two?
1) Need example of how to disable a custom button (or any control) that
was added to a Vantage form/sheet.
2) I have code on a button event to update the partnum field on the
Vantage quote entry form (line sheet) BUT I need to determine if NEW
LINE has been executed first. Is there a easy way to determine this?
I am slowly learning but still have a long way to go...
Bill
that
NEW
this?
> Thanks,
> Bill
button.enabled = false in control properties window
In the newline event set the button.enabled = true
>In the newline event set...
I will admit that I am completely green... You must assume that I know
how to define the "newline event" - Rule, Form, Event Wizard? And
there is nothing that sticks out as "newline" event -
AfterAdapterMethod, AfterRowChange, etc.??? Sorry if I SHOULD know
where this event can be defined.
Any additional direction?
Note: I do have programming experience, just the whole V8 customization
and .NET is new to me.
know
customization
> Thanks
Sorry, the way you defined what you needed led me to believe you
already had a way to tell when a new line was added :-(
How about the EpiViewNotification addrow method?
>led me to believe you already had a way to tell when a new line was
>added
Visually, yes, programatically, no :~)
Your suggestion worked - thanks.
Thanks again...
> Thanks again...
