Did that on my 8.00.811 test setup - which is down and out now.
Probably will not have 8.03 up and running again until next week.
Sorry.
Sorry.
--- In vantage@yahoogroups.com, "Joe Rojas" <jrojas@...> wrote:
> I followed your example to the letter and still no luck.
> What version are you on? I'm on 8.03.304C. I wonder if I've stumbled
> across a bug...
> Thanks,
> Joe Rojas
> IT Manager
> TNCO, Inc.
> 781-447-6661 x7506
> jrojas@...
Behalf
> Of bw2868bond
> Sent: Monday, March 19, 2007 2:04 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: V8 - Trying to figure out how to add a sub-
table
> view
> I guess that is why there is not too much left on the top of my
> head :-)
> Any how, I created a FKV on SugPoDtl called Part
> Column Name: SugPoDtl.PartNum
> Like Column Value: Part.PartNum
> Then I created a STV called PartPlant
> Parent view being Part.
> Sub Table Name: PartPlant
> Link Columns View: Part
> Parent View Columns:
> Part.Company -> PartPlant.Company
> Part.PartNum -> PartPlant.PartNum
> I save the customization, exited and re opened. I added a text box
> and gave the data source as PartPlant and field as LeadTime and it
> works OK
> Check to see if the views are using the same tables/links...
> --- In vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> , "Joe
> Rojas" <jrojas@> wrote:
> > Unfortunately I don't even know what that means :-(
> > I noticed something weird when creating the sub-table view.
> > The FKV I created is called PartInfo and the STV I created off of
> > PartInfo is called PartPlantView.
> > When I go into the Data Tools window and select my STV is shows
> that the
> > "Link Columns View" as PartInfo but when I click Edit Custom View
it
> > changes to SugPoDtl.
> > Also, all the columns in "Parent View Columns" are for SugPoDtl. I
> > wonder if this is part of my problem....
> > I wish there was better documentation of how to use the data
tools.
> > Thanks,
> > Joe Rojas
> > IT Manager
> > TNCO, Inc.
> > 781-447-6661 x7506
> > jrojas@
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> Behalf
> > Of bw2868bond
> > Sent: Monday, March 19, 2007 10:33 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> table
> > view
> > Off the top of my head.... Did you supply a constant for the
Plant ?
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%
> > > Hello,
> > > We notice that PO Suggestions are not taking into account the
> lead
> > time
> > > that is specified in PartPlant. I called tech support and
they're
> > on it.
> > > In the mean time, I figured I would add a field to the PO
> > Suggestions
> > > screen that at least shows the lead time from PartPlant so that
> > buyer
> > > see something.
> > > I created a foreign key view from SugPoDtl to the Part table
and
> > then a
> > > sub-table view from my foreign key view to the PartPlant table
> using
> > > Company and PartNum as the link columns.
> > > I then added a texbox that is bound to PartPlant.LeadTime but
> this
> > box
> > > doesn't show the values in this field. In fact it shows nothing.
> > > Am I missing a step?
> > > Thanks,
> > > Joe Rojas
> > > IT Manager
> > > TNCO, Inc.
> > > 781-447-6661 x7506
> > > jrojas@
