V8x Check Form Blank Title 56054
We are implementing with 8.03 and I found an Auto-Print Rule in the
Data Definition screen. However, it is greyed out when I select
APCheck.rpt. If I make a new rule I can access it. Is anybody using
this feature? The help for this is non-existant and I am wondering
if its new and not ready for prime time....
Jeremy
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...> wrote:
> > How do you get Vantage to print the second copy? I have a printer
> > with the blank checks in one drawer and yellow paper in the other
> > drawer.
> Currently, we just open up the Crystal Designer and browse to the
XML file in
> the MfgSysData\Reports\<username> and print from there. I'm sure
there's a way
> to call a Crystal Report from .Net but I haven't had time to figure
it out
> just yet. Probably something along the lines of
> objReportDocument = New CrystalReport()
> objReportDocument.SetDataSource(dataSet)
> CrystalReportViewer.ReportSource = crReportDocument
> Where you load dataset from the ADO.XML datafile. Maybe someone can
fill in
> the gaps and we can assign it to a button on the form.
> Mark
Does anyone have a Crystal check form that has the Check in the middle
of the page and a stub on top and a duplicate stub on bottom? If so,
would you mind sharing? I want to use this type of check as opposed to
the standard stub on top check on bottom form that is used as the
standard Vantage form.
Todd Hofert
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
We do, but it limits us to 14 line expense items per page. Other than
that it works well.
Gerard M Wadman
Sr. Network Systems Engineer
Scandius BioMedical Inc.
11A Beaver Brook Road
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
http://www.scandius.com/
This e-mail is for the use of the intended recipient(s) only. If you
have received this e-mail in error, please notify the sender immediately
and then delete it. If you are not the intended recipient, you must not
use, disclose or distribute this e-mail without the author's prior
permission. We have taken precautions to minimize the risk of
transmitting software viruses, but we advise you to carry out your own
virus checks on any attachment to this message. We do not accept
liability for any loss or damage caused by software viruses
Of Todd Hofert
Sent: Wednesday, April 04, 2007 9:09 AM
Subject: [Vantage] V8x Check Form
Todd Hofert
Todd asks:
Can I assume that you want the middle stub so you have a copy to keep with
your records? If so, we took a different tack. We created a second check
"image" with "Not negotiable" all over the darn thing. After we print the
regular checks, we reprint them with our "check copy" version. This has
several benefits:
1.) You're not limiting the number of lines per check
2.) No bursting
3.) You can add other information to the copy that doesn't appear on the
check.
The only draw-back is getting Vantage to automagically print the second copy.
Mark W.
Nice, I like that solution.
I wonder if there is a way to use the Label Print Control functionality
And yes it is for our records copy, which I really don't completely
understand why we need the a printed second copy. Isn't the db based
copy sufficient?
Todd
Of Mark Wonsil
Sent: Wednesday, April 04, 2007 11:13 AM
Subject: RE: [Vantage] V8x Check Form
Todd asks:
with
the
several benefits:
2.) No bursting
check.
copy.
Mark W.
Mark,
drawer.
Jeremy Jackson
WaterFurnace International
> Todd asks:
middle
so,
opposed to
keep with
check
print the
has
> several benefits:
> 2.) No bursting
on the
> check.
second copy.
> Mark W.
> drawer.
I set up one like that... the check printing company had them available with the 2nd copy already interleaved, so you just stuffed the whole ream in one drawer. It really wasn't all that expensive -- less then 20 cents per check iirc.
I did a little hack on the print server to modify the PCL code on the fly to print 2 copies (it was an old, cheap and not too smart HP) but most the new HPs let you configure for multiple copies in their regular setup.
-Wayne
> drawer.
Currently, we just open up the Crystal Designer and browse to the XML file in
the MfgSysData\Reports\<username> and print from there. I'm sure there's a way
to call a Crystal Report from .Net but I haven't had time to figure it out
Where you load dataset from the ADO.XML datafile. Maybe someone can fill in
Mark
