Good Day:
RE: Value of a PartDtl transaction- File\Field?
I recently discovered the PartDtl file which is, sort
of, the time-phase screen records minus MRP suggestions\Plans.
I am trying to use the PartDtl file to get a "Value-of-Demand-By-Month".
The PartDtl record does not have a dollar value field. Is there another
FILE that I could link to get the value of the transaction, Or do I
have to link to a couple of files. I cannot use Ave(or Last)-cost
because some transactions are just the PO-sub value or Issued-Parts
value.
I also need to figure out which to include. There are fields for:
InvTrans-Y-N, Requirement-Flag-Y-N, Type-Mtl-Sub, and
Source(several codes).
I think I will end up just using JobMtl, PoDTl, etc if PartDtl does not
have a child file that is the value.
Len
Len.hartka@...
Leonard C. Hartka
66 Loveton Circle, Sparks, MD, 21152
Work: 410-329-3560 ext 120
FAX: -329-3564
Work Cell: 443-255-7192
Personal Cell: 410-292-8744
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
value.
Len
Len.hartka@...
Leonard C. Hartka
FAX: -329-3564
