Mark,
I bit the bullet yesterday and installed Progress 9.0B then Vantage
4.0 then all the updates. It works perfectly and after restoring a
snapshot of the db from the old server and copying the reports folder
across, we're good to go.
I had to re-install the client software to get it to recognise some
of the new paths but so far, it's looking good.
When we had an Epicor Dev look at our 803 installation, he mentioned
that our Vantage 4 DB could do with a 'dump and load' to sort out the
high scatter factor. It would be the icing on the cake to sort that
as well!
Jonathan
as well!
Jonathan
--- In vantage@yahoogroups.com, "Mark Caldwell" <mcaldwell@...> wrote:
> Jonathan,
> When we moved 5.1 to a Windows server 2003 machine it wouldn't run
> Progress 9.1C. We had to install Progress 9.1D to run on 2003. I
think
> there was someone else on this list that ran into the same
problem. If
> 9.1C doesn't run on 2003 I would think 9.0B probably won't either so
> make sure you have the 9.1D install files ready.
> Good luck,
> Mark
Behalf
> Of jonnyfatman666
> Sent: Sunday, April 22, 2007 9:30 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Vantage 4.0 and 8.03 on same server
> Hi all,
> We're delaying our move to 803 due to dedicating time to other
issues
> but our V4 server has
> random reboots which seem to be very difficult to pin down (could be
> hardware related). It's
> running Windows NT4 Server and only has a 550MHz processor and
256MB ram
> and I'm
> desperate to retire it due to us having a nice new server to put
Vantage
> 803 on.
> My question is, in the meantime can I put Vantage 4 with progress
9.0B
> on the same server
> as our trial V8 install with openedge (Windows server 2003)? Would I
> have to fiddle around
> with environment variables and port numbers or should it be fairly
> straightforward?
> We've got 11 users so it's not a very demanding install.
> Cheers,
> Jonathan
