Vantage 6.1 and AutoVue 19.3
We went from V17.1 to 19.3 because some of the files our CAD dept. receives
and use. If I remember right it has to do with the newer version of AutoCAD
Inventor files (V.2009 or 2010).
Randy Duly, BSBIS, MCP, A+
IT Manager
National Tube Form
A Global Tube Form Company
3405 Engle Road
Fort Wayne IN 46809
P: 260-478-2363
F: 260-478-1043
C: 260-402-3216
<blocked::http://www.nationaltubeform.com/>
<http://www.nationaltubeform.com/>
This e-mail transmission and any attachments to it are intended solely for
the use of the individual or entity to whom it is addressed and may contain
confidential and privileged information. If you are not the intended
recipient, your use, forwarding, printing, storing, disseminating,
distribution, or copying of this communication is prohibited. If you
received this communication in error, please notify the sender immediately
by replying to this message and delete it from your computer.
I swear I asked this question recently but don't see it on the list. So I will ask again. Is there anybody running Vantage 6.1 and AutoVue 19.x. I installed it and cannot get it to work right.
If you have admin rights, it works fine whether you have quotes around parameter or not.
Example: w:\mfgsys61\av\avwin.exe &1 for view
w:\mfgsys61\av\avwin.exe -p &1
if your folder names are longer than 8 characters you are suggested to use quotes around the &1, such as "&1".
This works fine from the server or admin workstation. I got it to work on a couple users' workstation by using the quotes around the parameters but this was not consistent.
Anybody else have problem using Autovue 19.3 on Vantage 6? How about on Vantage 8.03, since we will be switching to that version shortly?
TIA,
Randy Duly
BTW I did uninstall AutoVue 17.1, reboot server, installed AutoVue 19.3. Did not change any security becuase AutoVue 17.1 worked fine before removing.
Randy
Does anybody out there use AutoVue 19.3 with Vantage?
Randy Duly
We have been a long time AutoVue user but were on version 18.
Patrick Winter
Of randyduly
Sent: Thursday, October 15, 2009 8:52 PM
Subject: [Vantage] Vantage 6.1 and AutoVue 19.3
Randy Duly
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
Just in case anyone want to know. I got AutoVue 19.3 to work on Vantage 8 by using the UNC naming convention.
I still cannot get it to work on Vantage 6.1 yet. I will let you know if I get it working, because someone responded to me offline she wanted to know if I got it working because she was having the same problem.
> Randy Duly
