Dennis
You need to make sure the client setup and compiled report includes the
export dll's
Gary
Dot Net IT Limited, Reg No 4412519
Of Dennis Houghton
Sent: 15 August 2008 14:58
Subject: Re: [Vantage] Vantage 6.1 odbc
I have tried #3 -3 different times and have had problems getting to
work. When I get it set up I no longer am able to do exports out of
crystal, it gives an error message and says it has to close and there is
no uninstall for the compile reports so you have to go thru a lot of
renaming files and moving to the correct place. I am not familiar with
viewers, can users query parameters like you can in developer? Who has
these?
export dll's
Gary
Of Dennis Houghton
these?
><mailto:vantage%40yahoogroups.com>
> Gary,
> Do you know if you can create an executable from Crystal Reports XI? I
> cannot find an add on for that.
> Daniel
> _____
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
> Behalf Of<mailto:vantage%40yahoogroups.com>
> Gary Parfrey
> Sent: Friday, August 15, 2008 9:40 AM
> Subject: RE: [Vantage] Vantage 6.1 odbcyou
> Dennis
> The first license you need to buy is for Crystal Developer 8.5 which
> should already have. (Where you write your reports)you
> The problem with 6.1 is that if you want users to run those reports
> either need toconnections
> 1) Run from developer (would mean you need to have a copy of
> Crystal Developer 8.5 on every client?
> 2) Run from a viewer (licensed depending on whether the viewer is
> free or not)
> 3) Run from an executable (need to get hold of the Crystal 8.5
> add-on compiler which is free. If you are using a later version of
> Crystal I believe the compiler is not available as they started using
> web based publishing.
> Item 1 is an expensive overkill and would need licensing for every
> terminal
> Item 2 Only need licenses if viewer is licensed and not free
> Item 3 does not need licensing as it accesses progress odbc
> only and the compiler is freeOn
> You will only need to buy Vantage licenses, if you add the executables
> to the vantage menu (using a progress script) and the user needs to
> login to find them
> This is how I have always interpreted it.
> Gary
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]
> Behalflicenses
> Of Dennis Houghton
> Sent: 15 August 2008 12:28
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Since I am on Vantage 6.1 will I have to purchase more crystal
> for each user? I am set up for crystal and have developed reportswhich
> others need to access now..com
> Mike Lowe wrote:
> > I think you probably have far more Progress licenses than Vantage
> > licenses. But you'll need to confirm with your contracts to get the
> > actual count.
> > Mike Lowe
> > Corporate I.T. Manager
> > Connor Manufacturing Services
> > Direct: (949) 713-3328
> > Fax: (949) 666-5268
> > Cell: (949) 973-7621
> > Skype: Mike.Lowe
> > Email: MLowe@connorms. <mailto:MLowe%40connorms.com> com
> > <mailto:MLowe@connorms. <mailto:MLowe%40connorms.com> com
> <mailto:MLowe%40connorms.com>>
> > Web: www.connorms.com <http://www.connorms <http://www.connorms.com/
> <http://www.connorms.com/>>
> .com/
> <http://www.connorms.com/>> .com/>>
> > ________________________________
> > Behalf
> > Of Dennis Houghton
> > Sent: Thursday, August 14, 2008 1:29 PM
> > Ok, thats great, can I assume that I have 10 progress licenses along
> > with the vantage licenses?
> > Mike Lowe wrote:
> > > I believe it only consumes a Progress license.
> > > Mike Lowe
> > > Fax: (949) 666-5268
> > > Skype: Mike.Lowe
> <http://www.connorms.com/ <http://www.connorms.com/>>
> .com/
> <http://www.connorms.com/>> .com/ <http://www.connorms
> <http://www.connorms.com/ <http://www.connorms.com/>> .com/>>
> <http://www.connorms.com/ <http://www.connorms.com/>> .com/>> >>
> <mailto:vantage%40yahoogroups.com>reports
> > > Behalf
> > > Of Dennis Houghton
> > > Sent: Thursday, August 14, 2008 1:13 PM
> > > To: vantage
> > > Subject: [Vantage] Vantage 6.1 odbc
> > > Can someone in this group tell me if using odbc and crystal
> > takeSystem.
> > > a full vantage seat or license?
> > > We have 10 vantage licenses and are using these for vantage.
> > > Thanks
> > > Dennis
> > > __________________________________________________________
> > > This email has been scanned by the MessageLabs Email Security
> System.
> > > For more information please visit http://www.messagel
> <http://www.messagelabs.com/email <http://www.messagelabs.com/email>>
> abs.com/email
> > <http://www.messagel <http://www.messagelabs.com/email
> <http://www.messagelabs.com/email>> abs.com/email>
> <http://www.messagelabs.com/email>> abs.com/email>>
> > > Internal Virus Database is out-of-date.
> > > Checked by AVG.
> > > Version: 7.5.519 / Virus Database: 269.21.8/1337 - Release Date:
> > 3/20/2008 8:10 PM
> > For more information please visit http://www.messagel3/20/2008 8:10 PM
> abs.com/email
> > Checked by AVG.
> 3/20/2008 8:10 PM
> Checked by AVG.
