(This is Adam; I work with Rob)
We found out what it took to get Vantage 8.0 in single user mode. All
of the changes are made on the AppServer itself. First off, make sure
your database is shut down and not set to automatically start. Next
pull up the properties for your AppServer, expand Agent and select
Properties. Replace the contents of the 'Server startup parameters'
with this:
-db C:\epicor\mfgsys80\db\mfgsys -1
Now click on Pool Range and set all values to '1'. At this point I
was able to hit OK, start the AppServer, and my Vantage client fired
up with no problems. The client seems to be running about twice as
fast in this mode.
with this:
fast in this mode.
--- In vantage@yahoogroups.com, "Gerard Wadman" <gwadman@...> wrote:
> You may be right, I guess the only way to tell is to shut down the App
> Servers, run the pro command and then see if the App Servers all start.
> Prowin32 can also be used and I believe with that utility, you can
> actually set a specific number of users.
> The PRO command will engage single user mode at the database level only
> as you suspect.
> Cheers
> Gerard M Wadman
> Sr. Network Systems Engineer
> Scandius BioMedical Inc.
> 11A Beaver Brook Road
> Littleton, MA 01460
> Of Mark Wonsil
> Sent: Friday, November 10, 2006 12:18 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: Vantage 8.0 Single User mode
> > Use the "pro" command
> > Open a command prompt on the DB server
> > Navigate to the appropriate DB directory
> > Type: "pro <db-name> -1"
> > The -1 parameter sets the db in single user mode however, I believe
> this
> > is optional as single user is the default parameter for the pro
> command.
> I guess we don't know until one tries but I wonder if setting the single
> user
> mode at the database will work. Does each appServer take a session? Task
> Agent? Aren't we really looking for a way to limit the number of
> sessions?
> What you may want to try is to open up your Progress Explorer Tool, do a
> properties on the AppServer, expand Broker (in the tree), choose
> Advanced
> Features and limit the Maximum Client Instances to one. I'm no expert
> but if
> you play around with this on your Test instance, you'll find out if it
> works
> without hurting anything. If you find some combination that works,
> please
> report back to the list as others may find it helpful.
> Mark W.
