Hi Chris,
Thanks for the info, will try that out.
Regards,
Christabel.
Chris Robisch <blue.wine@...> wrote:
We're heavily customizing PO Entry at Electroimpact. The best source I've
seen is the Vantage/Vista 8.0 Customization Lab (out)dated October 14 2004
which Support should be able to send you. Here's a few pointers.
You can't depend on the Visible property, at least on fields. It works on
some and seems to work on others until you enter data. Development has
stated the best method is to drag the field off the form to make it
invisible.
There's four tabs for PO Lines: Inventory/Other/Job Material/Subcontracting.
Each tab has its own grid and field order. We want all fields in the same
order so we can cut/paste to/from an Excel template. We'll send the
spreadsheet with data to/from the Supplier. But the field order is a
Personalization issue. Well, we don't want everyone required to do
Personalization. So when you're choosing the Customization file, click the
Base Only check box. This effectively becomes the default personalization.
Now you can change column widths, headings and field order and then add
further customizations. Once you've told Menu Structure Maintenance to use
the file, it'll apply to everyone.
Regards,
Christabel.
invisible.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, May 05, 2005 4:52 AM
Subject: [Vantage] Vantage 8.00.704 - The Customization Feature
> Currently i am exploring the customization features and encountered
> some issues as below :
> Original form in used : SO Entry form.
> 1. Cannot remove the tab (ie. Summary tab) from the original form.
> Action made :
> At customization tools dialog. I set the summaryPanel1 property,
> visible = false.
> Result :
> It only hide the content but the tab header remain visible.
> Can i remove the tab from the original form ?
> 2. System halt when i restore the summaryPanel1 property,
> visible = true.
> Anyone encountered the same problem ?
> 3. 'Del' function seems not working at the Customization Tool
> Dialog.
> I tried to use the delete function to remove the summaryPanel1
> from the tree view but nothing happen.
> Have anyone tried the customization features ? Is it working well ?
> Any idea where can i get more information on how to do
> customization ?
> Thanks.
> Regards,
> Christabel Hing
> GeniurSoft Sdn Bhd
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
Yahoo! Groups Links
To visit your group on the web, go to:
To unsubscribe from this group, send an email to:
Yahoo! Mail Mobile
Take Yahoo! Mail with you! Check email on your mobile phone.
