In 8.0 or above in go into Help then Contents, Engineering, Operations,
Costing Workbench. This give steps to create a group, load cost details do a
rollup and then post it.
The biggest challenge we found was knowing where the BOM Cost report
(outside of costing workbench) and Print Cost Set Group is getting it's
values from. As long as you know where these costs are being pulled from you
can make the appropriate changes.
Scott
Kevin Kennedy
Sent: Friday, November 02, 2007 1:12 AM
Subject: RE: [Vantage] Vantage 8.00.811B - Cost Roll up
hi Jason
Let me know if you draw a blank. I will at least have a flow diagram (which
I would have given you I think). It was to do with Parts & Engineering.
cheers - Kevin Kennedy
From: vantage@yahoogroups.com on behalf of Jason Abramczyk
Sent: Fri 11/2/2007 3:12 PM
Subject: [Vantage] Vantage 8.00.811B - Cost Roll up
Does anyone have a cost roll up procedure that they would be willing to
email me? The guys that have started to do our roll ups are a bit
sketchy on the start to finsih of the process. I can stumble my way
through it but if someone knew where i could get a written step by step
work instruction it would make life for me a lot easier.
Jason Abramczyk,
Precision Parts
Yahoo! Groups Links
Scott
Kevin Kennedy
hi Jason
Jason Abramczyk,
Precision Parts
Yahoo! Groups Links
