Sorry for the last question, I've just updated Vantage to patch E and
after stopping and starting appservers everything is where it should
be.
Jonathan
--- In vantage@yahoogroups.com, "jonnyfatman666"
be.
Jonathan
>does
> Vantage 8.03 Help seems to refer to a 'Method Directive Maintenance
> Screen'. Does this appear automatically after installing BPM or
> it need to be added in manually thru Menu Maintenance?moment
> One last question: Which components of IIS need to be installed for
> BPM to work correctly? I've only got some boxes ticked at the
> in my Server 2003 install and I want to make sure all the relevantentered
> ones are enabled without selecting all of them.
> Jonathan
> --- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@> wrote:
> > > We've had 803 installed for a while until we realised that we
> didn't
> > > have license codes for BPM. Received them today and duly
> into
> > > system.
> > > Where is BPM on the Vantage menu, or is it another piece of
> software to
> > > install on the server?
> > It is both. You'll need to enter your codes to enable it in your
> Vantage menu
> > and install the BPM software onto your webserver (IIS). You'll
> find the setup
> > on the installation DVD. They seem to want to install it on the
> same machine
> > as your Vantage server to use sockets but you can install it on
> another
> > machine and it will communicate using the http protocol.
> > Mark W.
