You can use the Form Event Wizard to create the code for the form
load event.
In the Script Editor (not XML editor), beneath Module Script, in the
section:
'// Add Custom Module Level Variables Here **
is where you would Dim all your custom controls.
Create the event handler in a blank area.
load event.
section:
--- In vantage@yahoogroups.com, "Dan Shallbetter" <dans@...> wrote:
> Thanks I am fairly new at this. I looked under the object explorer
tool
> and the XML editor for code similar to what you posted. I am
uncertain
> where to make the changes you outline?
> Thanks to all who replied, nice to know that it's not just me. I
all
> ready wasted more time than I should of thinking it was just a
newbie
> error. It would be nice if it worked the way it should.
> Dan
Behalf
> Of bw2868bond
> Sent: Tuesday, April 29, 2008 7:51 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Vantage 8.03.404 Customization and Tab Stops
> The only way I have found to effectively control the tab stop
> property is to define a control of the same type (I use the same
> control name as the one I want to control)
> Private WithEvents txtContractNum As EpiTextBox
> Then in the form load event set the control to be equal to the base
> form control and set the tab stop property:
> txtContractNum = CType(csm.GetNativeControlReference("2bffa487-c458-
> 4d83-9c4f-532eaa9ecc66"), EpiTextBox)
> txtContractNum.TabStop = False
> Then you need to make an event handler that will change the tab
stop
> property back to false when the base form sets it true:
> Private Sub txtContractNum_TabStopChanged(ByVal Sender As Object,
> ByVal Args As System.EventArgs) Handles
txtContractNum.TabStopChanged
> '// ** Place Event Handling Code Here **
> If(txtContractNum.TabStop = True) then
> End If
> End Sub
> Now do this for every control you really want control over :-(
> So much for an easily customisable user experience....
> bw
> --- In vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> , "Dan
> Shallbetter" <dans@> wrote:
> > I am not working across group boxes. I am trying to turn the tab
> stop
> > off. Only part of my changes are saved. I get different results
> when
> > running multiple test on the same customization. I tried to edit
the
> > field properties using the XML editor but kept getting errors.
How
> do I
> > set the focus?
> > Thanks,
> > Dan Shallbetter
> > States Electric Mfg.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> Behalf
> > Of Robert Brown
> > Sent: Monday, April 28, 2008 8:18 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: Re: [Vantage] Re: Vantage 8.03.404 Customization and Tab
> Stops
> > On 403 it seemed to work but inconsistently - sometimes
it 'stuck'
> on
> > save and worked, sometimes it didn't.
> > On 404 it doesn't seem to work at all.
> > I just also tried setting a font to bold on an epilabel and it
> refused
> > to 'stick'.
> > Back to your tab sequence, the only customization (of many and of
> which
> > tab sequence changes were minor desired changes) - only one seems
to
> > have survived 403-404.
> > It used after data field value change events to SetFocus() to the
> next
> > desired control field.
> > Try it if it really is a big issue for you.
> > Rob Brown
> > --- On Mon, 4/28/08, Patrick Parker <pbparker@
> > <mailto:pbparker%40yahoo.com> > wrote:
> > From: Patrick Parker <pbparker@ <mailto:pbparker%40yahoo.com> >
Stops
> > Date: Monday, April 28, 2008, 4:28 PM
> > I tried modifying the tab order on the job entry and engineering
> > workbench myself and wasn't able to get them to save either.
> > We wanted the tab to move from the setup times directly to the
> > production time entry since those were the only two fields we
> > modified quickly when entering jobs/BOM details operations.
> > --- In vantage@yahoogroups .com, "Dan Shallbetter" <dans@> wrote:
> > > I have been trying to change the tab stop on a few fields that
do
> > not
> > > seem to apply the changes. Is there another property that
> controls
> > the
> > > tab stop setting?
> > > Thanks,
> > > Dan Shallbetter
> > __________________________________________________________
> > Be a better friend, newshound, and
> > know-it-all with Yahoo! Mobile. Try it now.
> > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
