[Vantage 8.03] Part Maintenance Security
What method did you use in BPM to prevent a delete of a SO? I tried
using SalesOrder.DeleteByID but it never triggers to run. Is there
some other method you are using?
--- In vantage@yahoogroups.com, "macfarmw" <matthew_macfarland@...> wrote:
> In 8.03.400 you can use BPM to prevent a delete. I set one up to
> prevent Sales Order from being deleted and it works very well. You
> can't disable the Delete button but the user gets a error message when
> try to delete.
I am trying to set up security on my part maintenance screen so that
only specific user groups can delete any parts. I don't know how to
do this. I have tried customizations, Process security, and BPM but
nothing works. Has anyone been able to accomplish this, or has any ideas?
Have you tryed setting permission to read only? For part maintenance
screen
--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...>
ideas?
I had read somewhere that read only was going to be added to the 403 patch,
but have not found anything. Were is the setting for read only use?
Sent: October 02, 2007 7:19 AM
Subject: [Vantage] Re: [Vantage 8.03] Part Maintenance Security
screen
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
ideas?
Have we forgotten that Part tracker is read only?
Anyway, you cannot delete a part if it has ANY transaction against it.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of vantage
Sent: Tuesday, October 02, 2007 7:36 AM
Subject: RE: [Vantage] Re: [Vantage 8.03] Part Maintenance Security
patch,
<mailto:dobby01%40btinternet.com> ]
screen
ideas?
If there are transactions, then the next best thing would be to
inactivate it. There is field level security and you can give access to
a select few to be able to activate or inactivate a part.
HTH,
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of vantage
patch,
screen
ideas?
We restrict any part maintenance to only our "Configuration" personnel. I created a group called _Configuration and then in Security Maintenance>Process Security brought up bo.Part.Update and at "Allow Access" referenced my _Configuration group. Anyone else can right-click on a part number and get to Part Maintenance, but if they try to make any changes they get the message "Access Denied (Update)"
-Karl- (Tip-o-the-hat to John Steele)
Need a vacation? Get great deals to amazing places on Yahoo! Travel.
I am curious as to what your change control process is instead of controlling this programmatically. My humble .02 cents- There should be one gate-keeper of the parts master and make the part menu "invisible" via menu security. Your change control process should control "activating" and inactivating" parts not deleting them. If Parts have been referenced elsewhere via any transaction, its not appropriate to delete them and I don't think vantage permits you to do this. If these are parts on second thought you've determined are not required in the system, then the gate-keeper/keeper of the parts master/owner should be the person deleting them. I hope that your current process doesn't arbitrarily allow anyone/few to just delete parts without an audit trail.
RSN
----- Original Message ----
Sent: Tuesday, October 2, 2007 4:20:16 AM
Subject: [Vantage] [Vantage 8.03] Part Maintenance Security
____________________________________________________________________________________
Tonight's top picks. What will you watch tonight? Preview the hottest shows on Yahoo! TV.
http://tv.yahoo.com/
That's exactly my point. I do not want just anyone being able to
delete a part. BUT, we do have many different people updating
information that is in the part master (ie. plant information,weight,
etc.) Because i have all these people maintaining the part, they all
would have access to delete the part.
> RSN
> From: laidig.systems <laidig.systems@...>
ideas?
Remember, A Part can not be deleted if it ever has any transactions against
it. This includes Inactive Parts.
Since you want to give people the right to modify the Part, but no one can
delete it if it ever has had a transaction against it.
Scott
laidig.systems
Sent: Tuesday, October 23, 2007 12:36 PM
> RSN
ideas?
________
Yahoo! Groups Links
On Menu Security did you give them access to Create New Parts? If yes
try taking that away and only allow them access to the the other menus
which allow updating of purchasing, inventory, BOM and other items. This
is based on 6.1 I am not sure if the menu security is the same in 8.03.
Jim
On Behalf Of Scott Litzau
Sent: Tuesday, October 23, 2007 1:22 PM
Security
no one can
Scott
Behalf Of
laidig.systems
information,weight,
all
of
should
should
If
not
to do
not
your
delete
> RSN
so that
how to
BPM but
any
ideas?
________
> http://tv.yahoo.com/ <http://tv.yahoo.com/>
must have
access. )
Builder and
Yahoo! Groups Links
If there are any transactions against the Part it cannot be deleted.
But if there are no transactions and you still want to secure the
Part Delete procedure, you will have to do a customization.
Unfortunately Part Delete is not a procedure against which you can
apply Process Security. - Monte Tomerlin
yes
menus
This
8.03.
> Jim
> Security
but
> no one can
> Scott
40yahoogroups.com>
> Behalf Of
> laidig.systems
40yahoogroups.com>
Security
to
> information,weight,
they
> all
instead
> of
> should
> should
them.
> If
> not
you
> to do
are
> not
parts
> your
> delete
> > RSN
> > From: laidig.systems <laidig.systems@>
40yahoogroups.com>
> so that
> how to
> BPM but
has
> any
> ideas?
> ________
the
You
> must have
> access. )
> Builder and
goto:
> Yahoo! Groups Links
You still need a workflow process/procedure method in place to control "many different people" updating the parts master and limit this down to a change control procedure to one or two people. Question is "Why are you having to update the parts master or modify parts so frequently?" unless you are right in the middle of initial parts entry or data load or some such initial process.
That being said, you can set up a new security group, and menu security to explicitly allow Part Maintenance to to the security group to access the PArt Menu item and Disallow from all other Security Groups, access to the Part menu item.
Due to a shortcoming in the current functionality of Vantage, when the inventory team/clerk is also shut out of this, they will not be able to enter new lots at the time of PO receipts of parts in the standard way, there is a right mouse click Lot Entry/Lot Search method to get around this small problem.
Sent: Tuesday, October 23, 2007 10:35:54 AM
information that is in the part master (ie. plant information, weight,
required in the system, then the gate-keeper/ keeper of the parts
> RSN
> From: laidig.systems <laidig.systems@ ...>
> To: vantage@yahoogroups .com
ideas?
____________ _________ _________ _________ _________ _________ _
> http://tv.yahoo com/
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Did you check the menu security maintenance? Don't give them access to
the Create New Parts but let them have access to the Update menu and
others as needed. We set up different groups and then determine which
groups have access to what menus. Then assign the Users to the
appropriate groups. Makes it much easier to add new users and give them
access to the correct menus.
Behalf Of RSN
Sent: Thursday, October 25, 2007 4:19 PM
Subject: Re: [Vantage] Re: [Vantage 8.03] Part Maintenance Security
<mailto:laidig.systems%40yahoo.com> >
weight,
all
of
should
should
If
not
to do
not
parts
your
delete
> RSN
so that
how to
BPM but
any
ideas?
Do You Yahoo!?
http://mail.yahoo.com <http://mail.yahoo.com>
try to delete.
ideas?
