> For those of you running Vantage 8.0 or 8.03.400 what Server Roles do youAt a minimum, you must have it be a File Server otherwise you can't share out
> have configured on your Vantange Server. Do you have it set just as an
> Application server or File Server as well?
the Epicor folder. We also have the application server role because this is
necessary for any web service dependent items. Other products, like the
Connect packages, require the application server role as well. Finally, we
also have the print server role enabled on our machine.
Mark W.
