Dave
I created a share for each user (sharename is the same as their
username), then map drive letter "G" to that share in their User
Environment profile tab under the "terminal Server home directory".
Then under each shared folder I created a directory "vntgwork". I then
copied the Vantage.vtg to Vantage2.vtg, and changed the working dir to
"g:\vntgwork" (also you need to copy the vantage.ini to vantage2.ini and
change the working dir to g:\vntgwork" Then I published Vantage as an
application as follows:
Command Line: v:\vantage\vantage.exe v:\vantage\vantage2.vtg
Working Dir: g:\vntgwork
Dave Schnorr wrote:
Britt Moelling
M&M Manufacturing Co., Inc.
Dave Schnorr wrote:
> I know this has been posted before, but can someone remind me how to[Click Here!]
> set up
> Vantage as a published app in Citrix Meteframe 1.0. Thanks in advance.
> -Dave Schnorr
> eGroups Sponsor
> We no longer allow attachments to files. To access/share Report
> Files, please go to the following link:
> http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it,
> go to www.egroups.com, login and be sure to save your password, choose
> My Groups, choose Vantage, then choose Files. If you save the
> password, the link above will work the next time you try it.)
Britt Moelling
