Vantage - BAQ Query / Help
''ShipDtl.PackNum = Constant: NullValue
Would the 'empty', default PackNum be '0' ?
(Null Values not really useful with Integers)
--- On Mon, 1/19/09, Chris Thompson <chriselectrix@...> wrote:
> From: Chris Thompson <chriselectrix@...>
> Subject: [Vantage] Vantage - BAQ Query / Help
> To: vantage@yahoogroups.com
> Date: Monday, January 19, 2009, 11:55 AM
> Hi,
> I’m trying to create a dashboard with the following
> information – we are almost there, but can’t get one
> part of it.
> Â
> Basically, Vantage has a Dashboard called Sales Order
> Shipment Status.
> Â
> We require a dashboard which will show us the following:
> Â
> Grid View: Sales Orders ... ALL
> Â
> ONE
> Grid View: Sales Orders ... WHERE ShipDtl.PackNum = Null
> In other words, we want to see a list of all Sales Orders
> that have not got a Pack Number allocated to them.
> Â
> TWO
> Grid View: Sales Orders .... WHERE ShipDtl.PackNum > 0
> AND ShipHead.ShipStatus <> SHIPPED
> This will display all orders that are packed (or started to
> be packed) but have not been marked as Shipped (in Customer
> Shipment Entry).
> Â
> THREE
> Grid View: Sales Orders .... WHERE ShipHead.ShipStatus =
> SHIPPED
> This will show all orders that have been marked as shipped.
> Â
> I will then put date filters on them.
> Â
> This dashboard is purely intended to be visual, therefore
> we do not want to publish and subscribe between grids.
> Â
> The problem is, we can’t quite get it to work.
> Â
> If we set up a BAQ with the following:
> Â
> OrderHed
> OrderDtl
> Customer
> ShipDtl
> Â
> We can get it to display a list of every single order on
> the system, and display a Pack Number against the order, if
> one is available.
> Â
> This satisfies ONE (above), except when we import it into a
> dashboard and try to filter the
> Â
> Â
> it gives us an error message telling us that ‘Invalid
> Filter: Alpha compare against Numeric Column:
> 'ShipDtl.PackNum = Constant: NullValue'.
> Â
> At this point, we are wanting to display any orders that do
> not have a PackNum. Do you have any suggestions for us to
> get this to work?
> Â
> Â
> For TWO and THREE, we need to introduce the ShipHead table
> to the above query (or a copy of the above query), and we
> want the BAQ to tell us the ShipStatus, which should show
> against all lines. The options should either be OPEN, CLOSED
> or SHIPPED. Then we need to introduce this BAQ into the
> Dashboard and filter on ShipHead.ShipStatus, where
> ShipStatus <> SHIPPED. This, alsong with the filter
> above will satisfy TWO.
> Â
> However, when I add the ShipHead to the bottom of the list
> on the BAQ, I get this error ...
> Â
> Â
> I am unable to add ShipHead to the BAQ successfully, I am
> unable to complete TWO and THREE. I realise that it is
> trying to link ShipHead.OrderNum which doesn't exiitin
> in 8.03.406a. I linked Shipdtl to ShipHead with PackNumLine.
> Â
> Â
> I would appreciate any suggestions or pointers as to where
> we are going wrong.
> Â
> We understand the concept, but we don’t know how to get
> around problems when they occur.
> Â
> Thanks,
> Â
> CHRIS
> Useful links for the Yahoo!Groups Vantage Board are: (
> Note: You must have already linked your email address to a
> yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for
> Report Builder and Crystal Reports and other
> 'goodies', please goto:
> (3) To view links to Vendors that provide Vantage services
> goto: http://groups.yahoo.com/group/vantage/linksYahoo!
> Groups Links
Hi,
I�m trying to create a dashboard with the following information � we are almost there, but can�t get one part of it.
Basically, Vantage has a Dashboard called Sales Order Shipment Status.
ONE
In other words, we want to see a list of all Sales Orders that have not got a Pack Number allocated to them.
TWO
Grid View: Sales Orders .... WHERE ShipDtl.PackNum > 0 AND ShipHead.ShipStatus <> SHIPPED
This will display all orders that are packed (or started to be packed) but have not been marked as Shipped (in Customer Shipment Entry).
THREE
Grid View: Sales Orders .... WHERE ShipHead.ShipStatus = SHIPPED
This dashboard is purely intended to be visual, therefore we do not want to publish and subscribe between grids.
The problem is, we can�t quite get it to work.
OrderHed
OrderDtl
Customer
ShipDtl
We can get it to display a list of every single order on the system, and display a Pack Number against the order, if one is available.
This satisfies ONE (above), except when we import it into a dashboard and try to filter the
it gives us an error message telling us that �Invalid Filter: Alpha compare against Numeric Column: 'ShipDtl.PackNum = Constant: NullValue'.
At this point, we are wanting to display any orders that do not have a PackNum. Do you have any suggestions for us to get this to work?
For TWO and THREE, we need to introduce the ShipHead table to the above query (or a copy of the above query), and we want the BAQ to tell us the ShipStatus, which should show against all lines. The options should either be OPEN, CLOSED or SHIPPED. Then we need to introduce this BAQ into the Dashboard and filter on ShipHead.ShipStatus, where ShipStatus <> SHIPPED. This, alsong with the filter above will satisfy TWO.
However, when I add the ShipHead to the bottom of the list on the BAQ, I get this error ...
I am unable to add ShipHead to the BAQ successfully, I am unable to complete TWO and THREE. I realise that it is trying to link ShipHead.OrderNum which doesn't exiitin in 8.03.406a. I linked Shipdtl to ShipHead with PackNumLine.
I would appreciate any suggestions or pointers as to where we are going wrong.
We understand the concept, but we don�t know how to get around problems when they occur.
CHRIS
