I can confirm that the "Create Jobs" button and "Order Job Wizard" method produce inconsistent results i.e. one extra padded zero. I have had to restrict my users to the "Create Jobs" button method.
Dele
Dele
--- In vantage@yahoogroups.com, "eivantage" <KYLEJ@...> wrote:
> You are not correct on one point: While the padding for our config is set up to be four, the quick ID either has a left-hand (sales order number) section of six characters or seven characters; not consistent AND not equal to the config setting of four.
> I'm trying to avoid talking about the method of creating jobs manually or as "next job" so as not to confuse. It is not the point here.
> The issue is the consistency (or lack of consistency). You are not addressing that lack of consisteny in your replies. Please, try creating a job from a sales order using the two methods... first use the button, then use the order job wizard. You should see the difference in the padding, and it shouldn't match what you have configured for your job number generation length, unless it is by coincidence. Oops, I forgot... ONE of the two results won't match what you have configured because they don't yield the same result!
> --- In vantage@yahoogroups.com, "CharlieSmith" <CSmith@> wrote:
> > The Create Jobs button and the Order Job Wizard are going to use the
> > quick job ID setting (Next Job or Order Release). The Job number (next
> > Job Number or the Order portion of the job ID) will be padded to the
> > number in the company config.
> > The Quick Job Entry will use the next Job number padded to the length in
> > the company config as the default job ID.
> > Charlie Smith
> > Smith Business Services / 2W Technologies LLC
> > www.vistaconsultant.com <http://www.vistaconsultant.com/> /
> > www.2WTech.com
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of eivantage
> > Sent: Saturday, July 17, 2010 4:39 PM
> > Subject: [Vantage] Re: vantage creating inconsistent job numbers...
> > The length of the job ID is only controllable for a job number that uses
> > the "next" available job number. It is not configureable for a "quick
> > job," which is what the "create jobs" button and the order job wizard
> > create (within sales order entry).
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > > The reason for this is that the job number is not really a number but
> > an
> > > alpha-numeric. Job ID's sort that way. The length of the Job ID is in
> > > the company config.
> > > Charlie Smith
> > > www.2WTech.com
