Vantage Data Warehousing
I have MSSQL. I don't have a big budget. I also have an IT staff of two (including me), and building cubes is something I don't know much about.
The process of building OLAP cubes, ETL workflows, and reports seems like a pretty big task. Realistically I have probably a half-dozen critical views that we'd need to build to satisfy most of the needs.
Sounds like CorVu is a bad idea though. That's good to know.
Anyone know anything about WhereScape Red? Basically they have a tool that automates the building of the data warehouse - you design it and then it does the code generation and scheduling behind the scenes for you. Looks pretty slick, but I have no idea of the cost.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Friday, September 04, 2009 9:47 AM
Subject: RE: [Vantage] (unknown)
CorVu is garbage. IMHO. Stay away from it. It's clunky, convoluted
and not intuitive for users.
Cognos is good.
Both require a lot of setup and initial expense.
If you have $$ budgeted for BI software, my 2 cents, is to use that
money and upgrade your database to SQL (assuming you are Progress).
Then you can do all the BI yourself and still use Crystal Reports,
excel, etc by building complex SQL queries and turning them into Views
for users to safely hit.
Either way you have to build cubes ("views") and construct everything
anyway. With this route at least you get the added benefit and freedom
of SQL.
Of Brian W. Spolarich
Sent: Friday, September 04, 2009 9:37 AM
To: vantage
Subject: [Vantage] (unknown)
We are on 8.03.4xx and are thinking about BI/reporting need beyond
BAQ, etc.
Epicor has CorVu for 8.x and EPM if we want to wait until we upgrade
to 9.0.
I am also looking at other alternatives including hosted services
(PivotLink) and commercial open source.
Do folks have particular success stories or other wisdom to share?
Our need are I think pretty typical.
Sent from my (br)iPhone
BAQ, etc.
to 9.0.
Cognos is good.
of SQL.
To: vantage
BAQ, etc.
to 9.0.
Ill more than second Vic's recommendation, and assessment of Corvu.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Vic Drecchio
Sent: Friday, September 04, 2009 8:47 AM
Cognos is good.
of SQL.
Behalf
To: vantage
BAQ, etc.
to 9.0.
I spent very little time looking at corvu after installing it and didn't like what I saw. Instead I chose to do the sql views route like Vic mentioned. I'd like to add that you can do sql views in progress, through you are limited because (as far as my experience goes) you can't do triggers, stored procedures and functions in dml/sql. From what I understand you could do this in 4gl or java, but I would prefer the sql server route as well.
> Cognos is good.
> of SQL.
> To: vantage
> BAQ, etc.
> to 9.0.
