Vantage Favorites Icons Disappear
Got this fix from support. Copying the MSComCtl.ocx file from the
Mfgsys60\ocx folder to the windows\system32 folder did the trick for
us.
Thanks for all the replys. Nice to know we weren't alone on this one.
Brian
On one workstation the icons within vantage do not show. The
description of the icon shows, for example, job tracker, order
tracker, etc, but the icon does not show. If you put the mouse
cursor over the area that the icon should be, a square is highlighted
and you can press it to open Vantage.
Please send me info on how to correct.
On some machines, the icons for the Favorites are missing, as well as
the menu tree icons.
RESOLUTION
There are two files that need to be replaced in the \windows\system32
directory on the client.
MSComCtl.ocx
MSVBVM60.dll
These files can be copied from the \mfgsys60\dll and \mfgsys60\ocx
directories.
--- In vantage@yahoogroups.com, "Martin Horton" <martinh@p...> wrote:
> We've had this and I did fix it, but I can't remember what I did.
I think
> it's something to do with OCX's. Try re registering the OCX's using
> regocx.exe in the vantage directory or re-installing vantage after
doing a
> full uninstall and cleaning the registry of any mention of progress
and
> vantage.
> Hope this helps.
> Regards
> Martin Horton
> Assistant Group IT Manager
> PRD Holdings Ltd
> DDI: 01902 639187
> -----Original Message-----
> From: carl.heeder@s... [mailto:carl.heeder@s...]
> Sent: 23 September 2004 20:49
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Vantage Favorites Icons Disappear
> Hi Brian,
> I show no Epicor icons in my Vantage application. They simply
disappeared
> one day- Just as you
> say the label is there and it works but the picture is not there.
> I also get an annoying message
> "object" does not fit in parent frame "object"
> message very very frequently. Must have something to do with screen
> resolution.
> Anyone else have this problem?
> Carl Heeder
> ST Inverter America
> 281-506-3146
> Mobile: 281-221-3421
> FAX 978-725-3057
> "Brian Stenglein"
> <bstenglein@clowst To:
> amping.com> cc:
> Subject: [Vantage]
Vantage
> 09/23/2004 03:12
> PM
> Please respond to
> vantage
> OK, don't anybody think I've been nipping the sauce at work, I wish
I
> had a bottle on days like this but anyway...
> Has anybody ever had their Vantage Favorites Icons disappear. The
> labels for the icons still exist and if you click where the icon
> should be they still work, the picture that should be there is
> missing.
> We've seen this happen now on 4 machines. Today I installed a file
> from Microsoft Office Update that I need to make an Access DB
> function properly on a Win XP machine and after rebooting the Access
> problem was fixed, but a while later the user called me and said his
> Vantage Favorites icons were missing. I don't have anything as
> concrete as this in the other 3 instances because I wasn't doing
> anything to them right before the disappearence.
> I think I asked about this several months ago after the first
> occurance. Vantage support seemed to think I was crazy when I asked
> them about it. We ended up wiping out the machine and rebuilding it
> and everything was fine. Figured it was just a software glitch.
> Recently we had it happen to another machine that my boss just set
up
> for a user. He went through the process of setting it up again and
> they disappeared again. He finds it very strange that it is only
> happening to us.
> BTW, we are at Vantage 6.0 and the problems are happening on WIN XP
> clients.
> I going to call support again, but I wanted to see what you guys had
> to say as well. Only 20 more minutes to go, and I will be finding a
> bottle!
> Brian Stenglein
> Clow Stamping Co.
must have
> already linked your
> email address to a yahoo id to enable access. )
Builder and
> Crystal Reports and
> other 'goodies', please goto:
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> (Embedded image moved to file: pic26537.gif)
> click here
> (Embedded image moved to file: pic30741.gif)
> Yahoo! Groups Links
> To visit your group on the web, go to:
> To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
must have
Builder and
> Yahoo! Groups Links
OK, don't anybody think I've been nipping the sauce at work, I wish I
missing.
Recently we had it happen to another machine that my boss just set up
happening to us.
clients.
bottle!
Brian Stenglein
Clow Stamping Co.
Hey Brian,
I called Epicor about this today. We just upgraded the
operating systems on some systems and the same thing happened here.
Epicor said that they do not have permission to the icon files.
Uninstalling and re-installing should cure the problem. I will be
trying this tomorrow.
regards,
Brian Stenglein
Clow Stamping Co.
Hi Brian,
I show no Epicor icons in my Vantage application. They simply disappeared one day- Just as you
message very very frequently. Must have something to do with screen resolution.
Carl Heeder
ST Inverter America
281-506-3146
FAX 978-725-3057
"Brian Stenglein"
<bstenglein@clowst To: vantage@yahoogroups.com
amping.com> cc:
Subject: [Vantage] Vantage Favorites Icons Disappear
09/23/2004 03:12
PM
Please respond to
vantage
missing.
happening to us.
clients.
bottle!
Brian Stenglein
Clow Stamping Co.
Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and
other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
ADVERTISEMENT
click here
Yahoo! Groups Links
We've had this and I did fix it, but I can't remember what I did. I think
regocx.exe in the vantage directory or re-installing vantage after doing a
full uninstall and cleaning the registry of any mention of progress and
vantage.
Hope this helps.
Regards
Martin Horton
PRD Holdings Ltd
DDI: 01902 639187
Hi Brian,
resolution.
Carl Heeder
ST Inverter America
281-506-3146
FAX 978-725-3057
"Brian Stenglein"
amping.com> cc:
09/23/2004 03:12
PM
Please respond to
vantage
missing.
happening to us.
clients.
bottle!
Brian Stenglein
Clow Stamping Co.
already linked your
Crystal Reports and
ADVERTISEMENT
click here
Yahoo! Groups Links
Yahoo! Groups Links
Brian,
Please give support a hard time about this. I had called on this almost
a year ago. The fix was to reinstall. Support knew that at the time, I
called back to close the call out with the answer. I believe the answer
came from the group. The problem is a DLL or something gets replaced
when you install office, or a service pack after Vantage. A simple
client reinstall should fix it.
Good luck,
Aaron Hoyt
Hittite Microwave
Sent: Thursday, September 23, 2004 4:12 PM
wish I
The
missing.
file
Access
his
asked
rebuilding it
set up
and
only
happening to us.
XP
clients.
had
finding a
bottle!
Brian Stenglein
Clow Stamping Co.
You must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129iblfst/M=295196.4901138.6071305.3001176/
D=groups/S=1705007183:HM/EXP=1096056820/A=2128215/R=0/SIG=10se96mf6/*htt
p://companion.yahoo.com>
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=group
s/S=:HM/A=2128215/rand=487654432>
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service <http://docs.yahoo.com/info/terms/> .
