Vantage Freezing - Corrupt Index?
Sounds like the same problem. It's holding up an upgrade to
5.1/5.2.
Thanks Mark and Gary.
Lonnie
--- In vantage@y..., "Gary Polvinale" <garyp@d...> wrote:
> Mark,
> May not be blank. Could be non-printable characters/control codes
entered
> accidentally. Those characters could cause your session to kack.
Vantage
> doesn't know what to do with it. I saw some of that when I was a
> programmer. If that's what it is, Vantage programming dept needs
to go into
> the database tables and manually delete that record and everything
> associated with it. Or rename it.
> Depending on what it is, it could be involved and tricky. That one
part and
> all of it's links needs to be isolated and dealt with. I wouldn't
attempt
> it myself. Talk to someone who knows the system intimately. I'm
assuming
> that's the Epicor programmers. Good luck.
> Gary Polvinale
> Denton ATD
> Milan OH
> -----Original Message-----
> From: Tario, Mark [mailto:mtario@a...]
> Sent: Thursday, October 24, 2002 10:44 AM
> To: vantage@y...
> Subject: RE: [Vantage] Vantage Freezing - Corrupt Index?
> We have, believe it or not, a blank part number record in our
system.
> It was entered while we were in 3.0 and none of the Vantage/Epicor
> people we've shown it to either understand it or can fix it.
> A similar problem occurs when we try to access it in the part
master.
> The whole session is immediately terminated without warning and you
have
> to log on again. As soon as you try to open, look at this blank part
> number, this happens.
> Mark Tario
> Accurate Gauge & Mfg., Inc.
> Vantage 5.0 patch 340
> From: Lonnie Drew [mailto:lonniedrew@c...]
> Sent: Wednesday, October 23, 2002 5:54 PM
> To: vantage@y...
> Subject: [Vantage] Vantage Freezing - Corrupt Index?
> I've experiencing something similar to the Job Entry screen
freezing,
> though probably not of the same origin. There are a handful of
> JobOper records that will freeze Vantage, and cannot be accessed
from
> any Progress tool.
> For example when I try to view the contents of one certain record in
> RB, it crashs. I can try to access the corresponding JobOper
> operation in Vantage, and it locks up. I can try to access the
> record in a program and the session crashes.
> When I dump that table it stops on that record, and I get an "access
> violation". Tried IDXBuild and get the same error when it processes
> that table.
> I've dumped all but JobOper, and exported all JobOper (except that
> record) with a program. Trying import to blank DB as I write, to be
> followed by a load, then another IDXBuild.
> If anyone has also noticed one or more records that cannot be
> accessed, I would definitely like to hear about it.
> Thanks,
> Lonnie
> Yahoo! Groups Sponsor
> ADVERTISEMENT
<http://rd.yahoo.com/M=237459.2482214.3917349.2146399/D=egroupweb/S=17
05
007183:HM/A=1267611/R=0/*http:/ad.doubleclick.net/jump/N2524.Yahoo/B10
71
> 650;sz=300x250;ord=1035410025855805?>
> <http://us.adserver.yahoo.com/l?
> pmail/S=:HM/A=1267611/rand=427823000>
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> <http://groups.yahoo.com/group/vantage/files/>
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
must have
Builder and
I've experiencing something similar to the Job Entry screen freezing,
JobOper records that will freeze Vantage, and cannot be accessed from
any Progress tool.
that table.
Lonnie
We have, believe it or not, a blank part number record in our system.
A similar problem occurs when we try to access it in the part master.
The whole session is immediately terminated without warning and you have
Mark Tario
any Progress tool.
that table.
Lonnie
ADVERTISEMENT
<http://rd.yahoo.com/M=237459.2482214.3917349.2146399/D=egroupweb/S=1705
007183:HM/A=1267611/R=0/*http:/ad.doubleclick.net/jump/N2524.Yahoo/B1071
<http://us.adserver.yahoo.com/l?M=237459.2482214.3917349.2146399/D=egrou
Mark,
May not be blank. Could be non-printable characters/control codes entered
accidentally. Those characters could cause your session to kack. Vantage
programmer. If that's what it is, Vantage programming dept needs to go into
Depending on what it is, it could be involved and tricky. That one part and
all of it's links needs to be isolated and dealt with. I wouldn't attempt
it myself. Talk to someone who knows the system intimately. I'm assuming
Gary Polvinale
Denton ATD
Milan OH
Mark Tario
any Progress tool.
that table.
Lonnie
ADVERTISEMENT
