Thank you all for the help.
Nancy
Of lonniedrew
Sent: Wednesday, November 16, 2005 12:15 PM
Subject: [Vantage] Re: Vantage - Print Report list
I think the problem was probably the path to ProWin32.exe. Ours exists
in the Progress\Bin directory, while the Vantage default is Prgs91D\Bin.
If you want a report list from PRLs, select each PRL, and its contents
will be appended to c:\ReportList.txt.
The GUI layout was designed with Progress defaults, so if you run it
from a Vantage MFG, the display will show with Vantage defaults, and may
appear crowded. You can include database connection parameters in the
icon command line but it should be ok without.
I just made a couple of changes to the program, such as a cleaner
program list output, enabled database connection messages when you run a
report, and better instructions.
Let me know if any problems.
Lonnie
Nancy
Of lonniedrew
Lonnie
--- In vantage@yahoogroups.com, "Dunn, Nancy" <ndunn@w...> wrote:
> Back in July Lonnie put a procedure in the shared folders to print
> Report Builder libraries.
> I have downloaded the procedure PRLView_w and renamed it PRLView.w He
> said to run it from an icon with the command line such as:
> X:\progress\bin\prowin32.exe -p x:\mfgsys61\ud\prlview.w
> I have tried a number of things and can not get this to work.
> Does any one know the specific steps to get this to work or how to
get a
> print out of all the Report Builder reports in the libraries?
> Thanks
> Nancy K. Dunn
> I. S. Manager
> Winco Industries Inc.
> 937 667-4476
> ndunn@w...
------------------------ Yahoo! Groups Sponsor --------------------~-->
Get fast access to your favorite Yahoo! Groups. Make Yahoo! your home
page http://us.click.yahoo.com/dpRU5A/wUILAA/yQLSAA/PhFolB/TM
Yahoo! Groups Links
