In addition to the other comments - try to build in as much redundancy as
you can. Dual hot swapable power supplies sized so that either can handle
the full load, dual fans, dual NICs (load sharing type would be good). Also
- a smaller, seperate, system disk off the RAID pair helps balance the load
and if the budget can be stretched have a warm spare (same size) for the
mirrored disks to fail-over to on the fly. Memory is cheap now so go for
1GB if you can - on seperate 512MB modules. DLT or some backup media big
enough to hold twice your disk capacity (even if not all used, yet) to avoid
future cartirdge swapping or deciding what not to backup. We have a single
Xeon 550Mhz CPU and I have not seen it as being a bottle-neck for 40-50
users. Dual would have been better for redundancy.
Just a couple cents worth.
-Todd C.
Harvey Vogel Mfg. Co.
Sent: Thursday, July 26, 2001 6:00 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Vantage server sizing
Hi Everyone,
Would anyone care to share knowledge/info on server sizing? We
are implementing Vantage for a user population of 75. Of these 10 will
link from a remote site via Terminal Server.
From your experience how would you size the primary database
server and the Terminal Server boxes? Needless to say this will be using
Windows 2000 Server.
Rob Croft
Email: racroft@...
-Todd C.
Hi Everyone,
Rob Croft
Email: racroft@...
