Vantage Upgrade Process
it might but i would run the process through testing 1st.
Sent: Tuesday, October 26, 2004 10:07 AM
To: Vantage Groups (E-mail)
Subject: [Vantage] Vantage Upgrade Process
I am planning on upgrading from 5.2 to 6.1 and I want to see if this
idea might work.
Is it possible to have 2 computers, one with version 6.0 and one with
version 6.1 setup. Then take the 5.2 database and copy it over to the
first computer with version 6.0.
Run the schema change on our database.
Then take that database and copy over to the second computer with
version 6.1 and run the schema change on it.
Will this idea work to get my database up to version 6.1 or do I need to
go through the normal process?
Any thoughts?
Jasper
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=12989m4d1/M=315388.5526708.6599542.3001176/
D=groups/S=1705007183:HM/EXP=1098886091/A=2372354/R=0/SIG=12id813k2/*htt
ps://www.orchardbank.com/hcs/hcsapplication?pf=PLApply&media=EMYHNL40F21
004SS> click here
<http://us.adserver.yahoo.com/l?M=315388.5526708.6599542.3001176/D=group
s/S=:HM/A=2372354/rand=883729642>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views of the sender and not necessarily the views of the company. The email and any files transmitted with it are confidential to the intended recipient at the e-mail address to which it has been addressed. It may not be disclosed or used by any other than that addressee, nor may it be copied in any way. If received in error, please delete and notify the sender via e-mail or sales@... quoting the name of the sender. Messages sent via this medium may be subject to delays, non-delivery and unauthorized alteration. This e-mail has been prepared using information believed by the author to be reliable and accurate. Unless expressly stated otherwise, this e-mail does not form part of a legally binding contract or agreement between recipient and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the use of this email or attachments. It is, therefore, your responsibility to scan attachments (if any).
I am planning on upgrading from 5.2 to 6.1 and I want to see if this idea might work.
Is it possible to have 2 computers, one with version 6.0 and one with version 6.1 setup. Then take the 5.2 database and copy it over to the first computer with version 6.0.
Then take that database and copy over to the second computer with version 6.1 and run the schema change on it.
Will this idea work to get my database up to version 6.1 or do I need to go through the normal process?
Any thoughts?
Jasper
That is the way we did it. You will also have to login and run the database
conversions on each computer for 6.0 and 6.1. We discovered most of the
converting and schema changing was on version 6.0. The upgrade from 6.0 to
6.1 was quick. We did a probackup and prorestore commands when moving the
database from one server to the other. If you just copy the database you
will have to issue the prostruct repair command...it's quick though.
FYI
Paul L
Alabama Specialty Products, Inc.
Sent: Tuesday, October 26, 2004 9:07 AM
might work.
Any thoughts?
Jasper
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=12989m4d1/M=315388.5526708.6599542.3001176/D=gr
oups/S=1705007183:HM/EXP=1098886091/A=2372354/R=0/SIG=12id813k2/*https://www
.orchardbank.com/hcs/hcsapplication?pf=PLApply&media=EMYHNL40F21004SS> click
here
<http://us.adserver.yahoo.com/l?M=315388.5526708.6599542.3001176/D=groups/S=
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
THANKS!
Sent: Tuesday, October 26, 2004 10:15 AM
Subject: RE: [Vantage] Vantage Upgrade Process
FYI
Paul L
might work.
Any thoughts?
Jasper
ADVERTISEMENT
here
_____
Yahoo! Groups Links
Yahoo! Groups Links
Since you can use Progress 9.1D to upgrade from 5.1 to 6.1 you can use one PC. Just install Vantage to different directories for each version. You dont have to reinstall Progress at all.
One thing I have found to make it much easier is to replace
ConnectOptions=-N TCP -H vantage -S 6000 -ld MFGSYS
with
ConnectOptions=-1 -i -B 90000
This will start Vantage in single user mode. This way you do not have to setup each database in Progress Expl. It also makes the conversions and schema changes run much faster.
Just a thought,
Jeremy
Any thoughts?
Jasper
Yahoo! Groups Links
I'm about to do some test upgrades as well, Jeremy do you then just reverse
the ConnectOptions back to
ConnectOptions=-N TCP -H vantage -S 6000 -ld MFGSYS to put the db back in
multi user mode (live mode) or do you have to do
something else?
Sent: Tuesday, October 26, 2004 9:26 AM
dont have to reinstall Progress at all. One thing I have found to make it
with
Just a thought,
Jeremy
might work.
Any thoughts?
Jasper
Correct, Switch it back (with your perameters instead of mine) and then set up Progress Exp. and you should be good.
Jeremy
From: Moore, Jim (Anniston) [mailto:jmoore@...-ots.com]
Sent: Tuesday, October 26, 2004 10:43 AM
To: 'vantage@yahoogroups.com'
something else?
with
Just a thought,
Jeremy
might work.
Any thoughts?
Jasper
Yahoo! Groups Links
Paul,
When you used probackup and prorestore to move the database, how did you handle the the fact that the database name of the 5.2 database is different than the database name of 6.0?
Jasper
FYI
Paul L
might work.
Any thoughts?
Jasper
ADVERTISEMENT
here
_____
Yahoo! Groups Links
Yahoo! Groups Links
Good question. Basically what you do is make a backup normally on the 5.2
server. Copy this backup the the machine your using for the 6.0 conversion.
Make a folder, name it whatever you like, and restore the 5.2 database
there. Since 5.2, 6.0 and 6.1 use the same progress version your good with
the commands. The name doesn't change at this point.
Pop your Vantage 6.00 CD in and after the autorun kicks select " Upgrade
Database from Existing Installation". This utility will gather all the
information it needs, like where your Mfgsys60 software directory is, which
directory progress is installed, and where your copy of the 5.2 database is
located. In the end you click the "Upgrade Vantage Database" button and
sit back. This took 1 hour 10 minutes on our 4GB database. Then it runs
you through the SchemaChange process and you end up with a new MFGSYS
database sitting there ready to be started.
Paul
Sent: Thursday, October 28, 2004 10:50 AM
Paul,
Jasper
FYI
Paul L
might work.
Any thoughts?
Jasper
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
ADVERTISEMENT
https://www <https://www>
here
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/> >
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
Yahoo! Groups Links
<http://us.ard.yahoo.com/SIG=129e5l5jt/M=281955.5530326.6602771.3001176/D=gr
oups/S=1705007183:HM/EXP=1099065097/A=2343726/R=0/SIG=12iearmim/*http://clk.
atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1098978697804585>
oups/S=1705007183:HM/EXP=1099065097/A=2343726/R=1/SIG=12iearmim/*http://clk.
Get unlimited calls to
U.S./Canada
<http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time=10989786
97804585>
<http://us.adserver.yahoo.com/l?M=281955.5530326.6602771.3001176/D=groups/S=
:HM/A=2343726/rand=939532553>
_____
Yahoo! Groups Links
