VBasic Help Blank Title 54604
I will give this a try next week. I was able to do what I wanted by
creating a database trigger, but I have not moved that to the live
system yet as it requires a database restart to implement the new
trigger. I would rather make it work like this than using a trigger.
Thanks.
--- In vantage@yahoogroups.com, "Podlin, Michael"
<michael.podlin@...> wrote:
> Have you tried removing the "set DATE-FIELD_1.scrvalue = {curdate}"
> assuming your "getcurdate.p" is in the mfgsys61\vbp folder, set the
On Entry code to runprog vbp\getcurdate.p
> Then for your getcurdate.p code:
> {vbp\vb.i}
> find subshiph where rowid(subshiph) = GetCurrentROWID() no-lock.
> if subshiph.date01 = ? or subshiph.date01 = "" then setDateValue
("subshiph.date01.SCRVALUE":U, Today()).
> Return.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf Of markewhittaker
> Sent: Wednesday, February 14, 2007 8:53 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: VBasic Help
> Just bumping this back up to the top in case anyone has any ideas.
> --- In vantage@yahoogroups <mailto:vantage%
40yahoogroups.com> .com, "markewhittaker" <markewhittaker@>
> wrote:
> > I have a VBForm that uses the field subshiph.date01. I want the
> form
> > to default the current date if subshiph.date01 is blank. I am not
> > having any luck.
> > In the frame attributes, I have this for On Entry:
> > runprog getcurdate.p
> > The program getcurdate.p contains this:
> > {vbp/vb.i}
> > DEFINE VARIABLE curdate as date no-undo.
> > find subshiph where (rowid(subshiph) = GetCurrentROWID()) no-lock.
> > if subshiph.date01 = ? then assign curdate = today.
> > else assign curdate = subshiph.date01.
> > return.
> > This is with Vantage version 6.1. I have tried many different
> > variations on this based on what I have seen in sample programs
and
> a
> > few questions here. No luck. Can anyone help?
> > Mark
I have a VBForm that uses the field subshiph.date01. I want the form
having any luck.
{vbp/vb.i}
return.
variations on this based on what I have seen in sample programs and a
Mark
--- In vantage@yahoogroups.com, "markewhittaker" <markewhittaker@...>
form
> having any luck.
> {vbp/vb.i}
> return.
a
> Mark
assuming your "getcurdate.p" is in the mfgsys61\vbp folder, set the On Entry code to runprog vbp\getcurdate.p
{vbp\vb.i}
if subshiph.date01 = ? or subshiph.date01 = "" then setDateValue("subshiph.date01.SCRVALUE":U, Today()).
Return.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of markewhittaker
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "markewhittaker" <markewhittaker@...>
form
> having any luck.
> {vbp/vb.i}
> return.
a
> Mark
