basically, trying to tick ISCISContractor checkbox but getting below error
“There are no records in the table ds.CSFUK_Vendor”
but if i manually tick in the supplier screen, it works. also, the same code works on client customization via adapters. but its not working via bpm.
any suggestions to resolve this?
PS: the problem is we couldnt update suppliers data if no records exist in CSFUK_Vendor table. to create a record, tick and un-tick ISCISContractor in Supplier maintenance under United Kingdom tab.
Epicor support suggested to do a DMT for all the suppliers but we have 24 companies and each will have around 250 suppliers.
Thought a quick fix be to update this checkbox in Vendor.GetByID pre-processing but not working.
foreach(var item in Db.Vendor.Where(i=> i.Company == Session.CompanyID && i.VendorNum == vendorNum))
string vid = item.VendorID;
using (Erp.Contracts.VendorSvcContract va = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.VendorSvcContract>(Db))
var vData = va.GetByVendID(vid);
if(vData != null)
try
vData.Vendor[0]["CSFUK_Vendor_IsCISContractor"] =true;
vData.Vendor[0]["RowMod"] ="U";
va.Update(ref vData);
catch(Exception ex)
Ice.Diagnostics.Log.WriteEntry(ex.Message);
