Vendor Ref in Multi-book GL journal
Hi, to help with cost analysis when posting a manual journal, finance use the ‘Reference’ on the journal line to capture the supplier ID. This works fine for single book journals but does not work for multi-book journals. I tried tried to add a BPM to post the reference but had no luck. Has anyone else experienced this?
Perhaps it’s worth reviewing how dynamic segments work. IIRC you can hook up the supplier ID to a segment. Check out the help for dynamic segments for more detail.
