I could not find a recent post on this, but would like some general knowledge help on payment entry as it relates to vendor addresses.
Background:
There is a vendor at address A that has a purchase point with address B. From what I incorrectly understand, in vendor entry, the address listed on the mailing address tab should be the remittance address (Address A), a location to which all of our checks owed to them should be sent. This particular vendor has payment method “system check”. Additional note: There is only one bank record for this vendor for a payment method type that is not system check at pay to address A, but I naively believe this should be ignored because it is a different payment method, but is probably interfering some how with the address logic determination.
The Problem:
For some reason, checks are printing to address B for this vendor, which is only listed on the purchase point tab (primary purchase point).
Looking through the related transactions, the only place address B is listed is on the actual CheckHed record’s bank address which is mixed and matched with the irrelevant VendBank’s name mentioned above. This is odd because address B only appears on the purchase point.
Question:
What is the logic for defining the remittance address for a payment?
What it seems like is the following goofiness:
Remittance address = ?
- VendBank matching Vendor.PMUID? VendBank’s PayToAddress
- VendBank exists but none match Vendor.PMUID? PO order address or primary purchase point address(?!)
- Otherwise Vendor Address.
