Vendor Ship-To Address
We are implementing 8.03.404x (soon to be .405x).
We customized the PO entry and PO form to show the Warehouse address
instead of the plant address. this seems to bypass the multi-plant
complication and still get the effect you need with one plant setup.
In your case then you would need to setup the receiving address as a
separate warehouse and then figure out the above PO entry
customizations.
Of course having said all of this, we have tested this and it seems
to work, but we are not live on this yet.
Hope this helps.
Brad Boes
Metalworks
--- In vantage@yahoogroups.com, Mark Wagner <mjfw2003@...> wrote:
> Trish, you can set up your receiving dock as either another
company or supplier and on the PO header where you have the option
to choose between customer, supplier, or plant (if you have multi
plant) you can click on it and it will allow you to receive to
another location.
> --- On Fri, 9/19/08, trish_0063 <trish_0063@...> wrote:
> From: trish_0063 <trish_0063@...>
> Subject: [Vantage] Vendor Ship-To Address
> To: vantage@yahoogroups.com
> Date: Friday, September 19, 2008, 8:57 AM
> I don't know if I am missing something obvious here or not. Is
there a
> set up file that allows me to set a default ship-to location for
our
> purchase orders? Our receiving dock does not have the same address
as
> our corporate address. I am sure we are not unique. Any thoughts?
> Trish Abrams
> KMC Controls
I don't know if I am missing something obvious here or not. Is there a
set up file that allows me to set a default ship-to location for our
purchase orders? Our receiving dock does not have the same address as
Trish Abrams
KMC Controls
If it never changes, you could just customize the form.
Mark W.
The way we worked around that since we have 2 buildings we receive at is to
put both addresses under "vendor" and then our purchasing department picks
which building is to appear on the purchase order. Not real elegant but it
works.
Kathy Schaich
Operations Support Manager
Ultra Tool & Manufacturing, Inc.
W169 N5954 Ridgewood Drive
Menomonee Falls, WI 53051
Phone: 262-703-0455
Fax: 262-703-0468
Toll Free: 800-779-3566
kathy.schaich@...
www.ultratoolmfg.com
The information contained in this electronic message (email) and any
attachment(s) to it is/are intended for the exclusive use of the intended
addressee(s) and may contain information that is confidential and/or
privileged and exempt from disclosure under applicable law. If you are not
the intended recipient(s) and have received this communication in error,
please do not distribute it. Instead, please notify Ultra Tool &
Manufacturing, Inc. at 1-800-779-3566 or by email at
general@... and destroy all copies of this message and any
attachments. Thank you.
Mark Wonsil
Sent: September 19, 2008 11:08 AM
Subject: RE: [Vantage] Vendor Ship-To Address
Mark W.
Thinking of it from Epicor's perspective (ouch! my head hurts!) multi-plant capability is intended for this (although from a real world point of view it is ridiculously overkill).
Your receiving location is in essence a separate plant and then (presumably) you transfer the received inventory to your manufacturing/order fulfillment location...
What the accounting burden of this might be is only a guess - but I'm sure it is not inconsequential.
Food for thought though.
Rob Brown
Date: Friday, September 19, 2008, 12:19 PM
works.
Kathy Schaich
Phone: 262-703-0455
Fax: 262-703-0468
kathy.schaich@ ultratoolmfg. com
www.ultratoolmfg. com
general@ultratoolmf g.com and destroy all copies of this message and any
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Mark Wonsil
To: vantage@yahoogroups .com
Mark W.
Trish, you can set up your receiving dock as either another company or supplier and on the PO header where you have the option to choose between customer, supplier, or plant (if you have multi plant) you can click on it and it will allow you to receive to another location.
Trish Abrams
KMC Controls
