That was our problem the auto recieve button was checked.
Thanks for helping me find this issue.
Now at least we can go through and edit all jobs to not auto recieve
and stop bleeding inventory.
Our production managers are not going to like going back to it being
a 2 step process IE: Labor Entry then Job Reciept to Inventory but
oh well thats life till Epicor fixes this.
Mark Jervis
--- In vantage@yahoogroups.com, "prince_ashe_mark"
Mark Jervis
>2
> Ok I got ahead of myself.
> We have checked auto add to inventory whereas you probably do the
> step process.the
> We are going to test the 2 step process today.
> Mark
> <prince_ashe_mark@> wrote:
> > I'm lost when you say you perform a job reciept to get the
> > assembly's to Inventory ... Ours are automatic but thats where
> > problem starts.reciepts ?
> > Can you explain what steps you take to perform your job
> >the
> > Thanks,
> > Mark Jervis
> > --- In vantage@yahoogroups.com, "gsc1161" <gcreighton@> wrote:
> > > Ah -- sorry I can't duplicate, we backflush material, but
> perform
> > a
> > > job receipt to get the assembly to inventory.
> > > > Yes when we do the labor entry a job reciept to stock for
> > jobwrote:
> > > is
> > > > automatic.
> > > > I see the lot number when I go to quantity adjustment to
> adjust
> > > the
> > > > part number so we can ship the product.
> > > > Thanks,
> > > > Mark Jervis
> > > > >For
> > > > > So I can simulate here, where do you see the Lot number?
> > > > > example, in the Part Tracker - Lots tab?in
> > > > > Do you perform a job receipt to put the finished product
> > > > > inventory?using
> > > > > > Yes we are using backflushing to issue the materials.
> > > > > > The lot number gets attached to any product made by
> > > labora
> > > > > > entry.
> > > > > > IE: Say we were building tables and we needed to create
> > > Smallwe
> > > > > > Parts Bag or Accessory Pack to go with that Part. When
> > > enterwith
> > > > > the
> > > > > > labor entry for making the bag kit those bag kits get
> > assigned
> > > a
> > > > > lot
> > > > > > number which is the same as the job number. Then when we
> > enter
> > > > the
> > > > > > labor entry for the final product that uses that bag kit
> we
> > > run
> > > > > > negative on the bag kits because we cannot use the bag
> kits
> > > that
> > > > > > have the lot number attached to them and we also run
> > negative
> > > > > final
> > > > > > product because we cannot ship the product that has been
> > > > assigned
> > > > > a
> > > > > > lot number.
> > > > > > Therefore our inventory numbers keep growing not only
> > > finalthe
> > > > > > products but also any assembled products that go into
> > > finaland
> > > > > > products.
> > > > > > As you can well assume it is creating a huge Inventory
> > > > > > Accounting nightmare.part
> > > > > > I am able to identify all the parts in inventory with a
> lot
> > > > number
> > > > > > attached by building a BAQ looking for lot numbers.
> However
> > > the
> > > > > > extra labor everyday for this is getting out of hand.
> > > > > > Thanks,
> > > > > > Mark Jervis
> > wrote:
> > > > > > > Are you using backflushing to issue material? I am
> > > confused,
> > > > > does
> > > > > > > the lot code get attached to the finished assembly
> > > > number,that
> > > > > or
> > > > > > > the components withing the BOM?
> > > > > > > > We are a manufacturing firm. We set vantage up so
> > alland
> > > > our
> > > > > > > > finished products are reported and inventory is
> tracked
> > > > > through
> > > > > > > > BOM's (bill of materials)
> > > > > > > > Say for example we are building a table.
> > > > > > > > In our BOM we put:
> > > > > > > > 1 table top
> > > > > > > > 4 legs
> > > > > > > > 6 screws
> > > > > > > > At the end of the day when the supervisor for that
> > > assembly
> > > > > area
> > > > > > > > enters what his employees did for the day (IE: 6
> tables)
> > > it
> > > > > > > removes
> > > > > > > > all the small parts from our inventory as expected.
> > > > > > > > However it grabs the job number for the part built
> > > > assignsgets
> > > > > > the
> > > > > > > > job number as a lot number on the part.
> > > > > > > > We do not use lot numbers and therefore that part
> > > stuckcompany
> > > > > in
> > > > > > > our
> > > > > > > > inventory because with lot numbers turned off
> > wideadjust
> > > > we
> > > > > > are
> > > > > > > > not allowed to ship against that lot number or
> > > > > inventoryone
> > > > > > > > against that lot number.
> > > > > > > > I know everyones normal answer would be turn on lot
> > > numbers
> > > > > > > company
> > > > > > > > wide but thats not possible due to the fact we are
> > > plantadjust
> > > > > out
> > > > > > > of
> > > > > > > > a multiple plant operation.
> > > > > > > > Therefore in order to ship 6 tables we have to
> > thenumbered
> > > > > > > inventory
> > > > > > > > by 6 tables without a lot number and the lot
> > > tablebeyond
> > > > > > stays
> > > > > > > in
> > > > > > > > our inventory.
> > > > > > > > Accounting is seeing our inventory numbers grow
> > > > > control.month.
> > > > > > So
> > > > > > > a
> > > > > > > > work around for this is needed by the end of the
> > > > > > > >lot
> > > > > > > > Mark Jervis
> > > > > > > > Inventory Control
> > > > > > > > Prince Manufacturing (Asheville)
> <gcreighton@>
> > > > wrote:
> > > > > > > > > We are in pilot mode, and have not noticed this
> issue -
> > > > can
> > > > > > you
> > > > > > > > be
> > > > > > > > > more specific? What can I look for? Is the job
> > number
> > > > > being
> > > > > > > > > attached to material structured to the job as a
> > > > number?them
> > > > > > How
> > > > > > > > can
> > > > > > > > > I test this?
> > > > > > > > > > Hello,
> > > > > > > > > > I am having a problem with vantage and was
> wondering
> > > if
> > > > > > > anybody
> > > > > > > > > else
> > > > > > > > > > has run across this and found a work around.
> > > > > > > > > > Since we moved to Vantage 8 we have noticed when
> we
> > do
> > > > > labor
> > > > > > > > entry
> > > > > > > > > > vantage is taking the job numbers and putting
> > asfull
> > > > lot
> > > > > > > > numbers.
> > > > > > > > > > Now the problem: This has prompted us to do a
> > > > > physicalfor
> > > > > > > > > > Inventory. However we cannot adjust any items
> amount
> > > if
> > > > it
> > > > > > has
> > > > > > > > > been
> > > > > > > > > > assigned a lot number. Our system isn't setup
> > lotof
> > > > > > numbers.
> > > > > > > > > > Epicor tells us there will be a fix for this in
> > > October.
> > > > > > > However
> > > > > > > > > > this glich is putting our inventory numbers out
> > > > > control.physically
> > > > > > > > Which
> > > > > > > > > in
> > > > > > > > > > turn is affecting our accounting due to the fact
> we
> > > are
> > > > > > > showing
> > > > > > > > a
> > > > > > > > > > large number of items in stock that we
> > > don'tnumbers
> > > > > have.
> > > > > > > > > > If anybody has found a way to adjust these
> > > > > > > automatically
> > > > > > > > > or
> > > > > > > > > > manually please respond.
> > > > > > > > > > Thanks,
> > > > > > > > > > Mark Jervis
> > > > > > > > > > Inventory Control
