I have had a request from ‘engineering’ to be able to view a method of manufacture in a graph type view similar to the way jobs are displayed in job status dashboard.
Inputs would be MoM and a run qty
the intent is to catch blatant errors in the method such as entering a 1 hour run time instead of .01 as an example…
actual scheduling and date constraints need not be considered, this would just be a tool to verify proper flow of the assembly
Anyone know if such a program exists in the Epicor realm or have advice on how to accomplish this task?
I haven’t seen anything like that, but If you use windowing functions with running sums or something like that, you can probably make a grid that translates to a chart in a dashboard pretty well. It won’t be a gantt chart like it is in the job sched board, but I think you could make something with a bar chart work.
