Needing help setting up deduction for HSA and needing to know if the W is put on W2 line 12 when using the HSA’s for the deductions special type.
In Payroll Deduction Maintenance you can select from a dropdown one of the two HSA special types.
Then when generating the W2 it will be put in the first available 12 box(a, b, c or d).
